Speedo Swap?
Car: 89 IROC-Z28
Engine: LS1 "ASA"
Speedo Swap?
Alright, I've heard everybody saying they were going to swap their slower speedo with the popular 145mph speedo, but never tell if it worked.
This has been confusing me for months, My speedo, which is a 115mph cable-driven, has gone to pieces, and what I am wondering is, if I change my speedo to the 145mph, will the needle be calibrated and lined up where it should be? So if I'm showing 55mph, then I am really rolling at 55mph.
Bascially what I am wondering is this, Can I just easily swap my 115 gauge to a 145 gauge, without and other modifications or swaps?
Thanks,
- Justin
Thanks,
- Justin
Re: Speedo Swap?
yup, just get a mechanical one as well. As long as your speedometer gears in the trans were calibrated properly and you were showing the correct speed before you swap, you should be fine.
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
Re: Speedo Swap?
it was ummmm 1990 went to an different style, 89 and below are ok, some early ones had the "Dual Pointer" but it still the same as a single pointer as for the speedo gears....
some Berlinetta's had a special digital one also
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Speedo Swap?
82-84 had the dual pointer, 85-89 the single. All mechanically driven. 90-92 were electric. No experience with Berlys.
JamesC
JamesC
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Re: Speedo Swap?
A mech speedo swap is just that, a swap. Now when you start changing gears and tire size is when you need to worry about speed differences.
Car: 1986 Camaro
Engine: 350 v8
Axle/Gears: 10 bolt,disks, 3.23 posi rear
Re: Speedo Swap?
Can I swap my 1984s 85mph speedo with a 145mph speedo?
Car: 89 IROC-Z28
Engine: LS1 "ASA"
Re: Speedo Swap?
If it is the "normal" (not the berretta double needle) style, then yes you can swap out the speedo. I'm not sure about how the berretta style would work.
but...
The only thing that can be a problem, from what I was told on here, is if you swap the whole gauge cluster, wierd things usually start to happen after a while.
So the suggestion is to just swap the speedo only.
but...
So the suggestion is to just swap the speedo only. Joined: Aug 1999
Re: Speedo Swap?
Just to clarify, all mechanical speedos, 82-89, are interchangeable. If the trip doesn't work, check the following link:
https://www.thirdgen.org/forums/faq-...-fix-pics.html
JamesC
JamesC
Car: 1986 Camaro
Engine: 350 v8
Re: Speedo Swap?
Mine has the double needle so it has the mph on one side and the kmh on the other side.
link does not work.
JamesC
JamesC
Last edited by chrisblazzer89; Feb 27, 2008 at 08:48 PM. Reason: Automerged Doublepost
Car: 1984 Camaro Z28
Engine: L69 305 H.O.
Re: Speedo Swap?
I did the swap on an 84 Z28 with the double needle. I went to a NOS 140 Z28 speedometer that GM offered as an upgrade. The calibration was WAY off. Showed I was going 100 MPH at about 60 MPH acual. The fix is to get a speedometer calibrator. There are a number of companies on the internet that will build you one. (Any Speedometer shop) It's a small mechanical device that screws into your transmission where the speedometer cable normally goes. Then the cable is screwed into the calibrator. I bought mine on the internet for $65.00 They figure out your ratio by having you drive a one mile course. You chart out exactly 1 mile on your local road or hwy. Set your odometer/trip to "0" You then drive that one mile course and stop. You then record what your odometer/trip recorded. Mine recorded something like 6/10 of one actual mile driven. You then give them the figure and they build the calibrator for you. Mine worked to within 1/2 mile per hour. The only other way is to swap out your drive/driven gear, which on a T-5 means taking off your tailhousing.
Re: Speedo Swap?
If all is stock in the car, there is no need to calibrate anything, simply swap one speedo head for the other. A rear end gear change is another story.
JamesC
JamesC
Re: Speedo Swap?
Nope, that's why there's so many different drive and driven gear combinations. There's a number of different speedometer face plates. 85, 110, 115, 140, 145, and a bunch I've probably missed. Although the speedometer heads are all engineered the same, the ratio in which the mechanical cable is turned is different, therefore you're going to get a different reading for each depending on the face plate you use. Thats why you can't simply screw on a new face plate and hope it'll work.
Re: Speedo Swap?
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Re: Speedo Swap?
False false false, the reason for all the different drive and driven gears are for the different rear end and rear tire size options avaible thoughout the GM lineup.
https://www.thirdgen.org/gauges
Car: 85 IROC
Engine: LB9
Re: Speedo Swap?
I've swapped speedo's (85's to 115's) in three thirdgens now...they all work fine and accurate. Member
Car: 1986 Camaro
Engine: 350 v8
Re: Speedo Swap?
Car: 85 IROC
Engine: LB9
Re: Speedo Swap?
temp sender that feeds the guage is screwed into the cylinder head on the drivers side between #1 and #3 cylinders. Be careful when removing it is in the water jacket and will puke coolant all over.
Oil pressure sender, IIRC is on the back of the motor somewhere, do a search as I am sure this has been discussed many times.
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
Re: Speedo Swap?
but...
but...
So the suggestion is to just swap the speedo only.Joined: Aug 1999
Re: Speedo Swap?
There can be electrical issues from time to time (I'm not sure why). If your cluster functions as designed, any possible issues can be avoided by simply swapping the speedo head. More often than not, however, a swap is straightforward.
JamesC
JamesC
Re: Speedo Swap?
When I did my 92 145 speedo swap in my 91 RS, I changed the whole cluster. The tach was acting weird, so I pulled the cluster back out and swap the tach PC board from my original cluster into the 92 cluster. Fixed it, no other issues.
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: Speedo Swap?
I wasn't aware that there were any mechanical speedos that read more than 85mph....or is that only in the Camaro's?
I also know that in firebirds they went from Mechanical to Electrical in 85...so I'm sort of screwed with my 84.
I would love to get a 120 or 145 gauge for my T/A.
I would love to get a 120 or 145 gauge for my T/A. Joined: Aug 1999
Re: Speedo Swap?
Just poking a little fun, suggesting Ozz's car didn't need a 115 or 140 speedo because his car wouldn't go that fast.
JamesC
JamesC
Car: 1984 Trans Am
Re: Speedo Swap?
I don't know--I read somewhere that the top end for an HO car was 138. Anyway, I have a terrible screechy noise from the passenger side when I hit about 90. It keeps repeating, "Now, you slow this car down right this minute!" Which begs the question of why I need a 140 either.
JamesC
JamesC
Re: Speedo Swap?
We're talking mechanical, you're talking electronic.
Re: Speedo Swap?
We were discussing general electric issues in a swap, not the speedo specifically. Those electronic issues can crop up regardless of year and type. Forgive me for saying so, but you seem to hanging on to a belief that's simply incorrect. Perhaps trying a search will provide you will a wider range of opinion than the ones expressed in this link.
JamesC
JamesC
Car: 1984 Trans Am
Re: Speedo Swap?
JamesC
JamesC
Re: Speedo Swap?
JamesC
JamesC
Car: 1985 Buick Regal T-type
Engine: TBI 5.7
Transmission: 2004r
Re: Speedo Swap?
We shall find out. I am getting ready to swap in a 88 iroc guages into my 82. I already have the sending unit. Tonight I tried to get the fitting for the mechanical one out and couldn't. Have to figure out how to get it out.
Vince
Vince
Re: Speedo Swap?
Um yeah, I can read. I put my experience in this thread so in the future, when someone with a 90-92 does a search a finds this thread. The info for 90-92 swaps is in hear. And the tach thing I was commenting about, could apply to earlier models. I just wanted to point out that if you did a whole cluster swap and the tach seems off, you could just switch the PC boards for the tach, at least in my case of putting a 92 Z28 L98 dash into a 91 RS LO3 car.
Re: Speedo Swap?
3.23's up require a blue 7-tooth drive gear, plus the following driven gear:
18 tooth (p/n 3987918) Brown = 3.23
19 tooth (p/n 3987919) White = 3.42
20 tooth (p/n 3987920) Blue = 3.45
21 tooth (p/n 3987921) Red = 3.73
22 tooth (p/n 3987922) Gray =3.77
3.08 has an 9-tooth drive gear.
Given that info, could your car have had the wrong gears to begin with? Perhaps a change (trans or rear) was made by a previous owner.
JamesC
Car: 1989 IROC-Z
Engine: 383 waiting on afr 195 comps
Re: Speedo Swap?
i think i have a simple solution to your problem and maybe i can give some advice from my own expieriance. i did the 115 to 145 swap on my 89 iroc. the speedo worked fine once i got the cable pluged all the way in. the electrical trouble is from a bad connection. you have to push pretty hardon the header plate and the face of the cluster. i know this because some of my gauges were showing that they were maxed out. after i fixed the problem it has worked flawless for 4 years. as far as trying to go with diff year speedos just try to find a way to drive both of the at the same rpm (like with a drill or something) then see if they show the same speed. i,ow need to find a way to change over to the 91-92 electric cluster to get my speedo to work with my 6 speed tranny. stupid electric vss.
Car: 1986 Camaro
Engine: 350 v8
Re: Speedo Swap?
Ok I found out that my oil pressure sender unit was not connected as in no wire to it. Now the thing is I can't find the wire that connects to it anywhere under there can some one plz take a picture of the area for me so I can at least know what I'm looking for.
Car: 1986 Camaro
Engine: 350 v8
Re: Speedo Swap?
If you like a bit of color in the cluster:
https://www.thirdgen.org/forums/body...r-cluster.html
JamesC
JamesC
Re: Speedo Swap?
so im sure this has been asked somewhere.. and i havent found it but.. can you.. or how much of a pain is it.. if you even can... swap the 85-89 guages into a '90? i prefer the full round gauges versus the half moon.. plus the gauges on mine dont work well anyway.. gas is WAY off and tach doesnt work at all... is it possible..?? a pain in the ***? or no way in hell will it work? thanks.
