Digital gauges
Old Jan 13, 2008 | 08:08 PM
DW92RS's Avatar
Digital gauges
ok guys ive done quite a bit of searching and cant find what i want..maybe someone here can help me.. i have a 92 RS vert that im restoring and custominzing.. i want to go with emerald green digital gauges in the dash and on the a pillar 3 3/8 speedo and tach the rest a little smaller like 2". the reason ive chosen these is im going with an "ALIEN" theme. with interior leather and custom work on the dash and trim...paint is gonna be my favorite.. i get to put my talent with airbrushes to work. Anyway... any help with the green gauges and display panel would be much appreciated..
pics would help too!
Old Jan 13, 2008 | 08:48 PM
VenomX-87's Avatar
Car: 1984 Trans-Am WS6
Engine: WAS: 5.0HO, SOON: ZZ383-425HP.
Transmission: 700R4 with shift kit
Re: Digital gauges
you mean like the Dakota Digital guages?
http://www.dakotadigital.com/index.c...=cat/cat70.htm
Im doing a guage cluster for my T.A soon but im going to use the blue ones if i do go digital.
Old Jan 13, 2008 | 10:03 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Re: Digital gauges
Dakota Digital doesn't stock the gauges for the 90-92 Camaro. They will fit digital gauges into the bezel you have.
http://www.dakotadigital.com/index.c...rod/prd214.htm
Standard colors are blue and teal because they are most visible when in the sun, but you can arrange with them to put green lighting in them.
Here are mine in teal, I've had them about 4 years now.
Old Jan 13, 2008 | 10:38 PM
QuickStyle's Avatar
Car: 91 Z28
Engine: 383 SuperRam
Transmission: ProBuilt 700r4
Axle/Gears: G92 3.23
Re: Digital gauges
wow thats a really nice gauge setup you got there, i can't see myself spending $1050 on that tho. im going to make myself a custom cluster with my choice of gauges, but not digital and it wont even cost half of that.
for the op - im not quite sure what your question is, but take a look at the thread in the link below, it might help you out.
https://www.thirdgen.org/forums/post...38-post10.html
Old Jan 14, 2008 | 12:30 AM
Al Hasse's Avatar
Re: Digital gauges
Another option is Nordskog which has the the panels for all year Camaros.
http://www.nordskogperformance.net/p...003-dp4005.htm
Old Jan 14, 2008 | 08:52 PM
mxcrazed's Avatar
Car: 87 firebird none soon
Engine: None
Transmission: none
Axle/Gears: 2.73 10 bolt
Re: Digital gauges
back in the day a company called cyberdyne yes like in terminator made a set that looked cool dono if you can get it in green though or if you will ever find one do a search and those Nordskog gauges are sick i must have them what would i do about my mechanical speed sensor in my t5 i know i can get put a electronic in there but how
Old Jan 14, 2008 | 11:58 PM
DW92RS's Avatar
Re: Digital gauges
found the one from cyberdyne and they look awesome and not to expensive.. i just have to make a custom panel to fit the gauges..i think itll work out though.. thanks for the help guys
[ATTACH][ATTACH]Digital gauges-volt1.jpg[/ATTACH][/ATTACH]
Attached Thumbnails Digital gauges-speedometer1.jpg   Digital gauges-tachometer1.jpg
InfernalVortex
Apr 20, 2021 11:31 AM
Lbibb
May 5, 2016 12:00 AM
rusty vango
Sep 29, 2015 02:44 PM
Eric-86sc
Sep 28, 2015 11:37 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
