Fixing the HVAC in my Camaro
Old Jan 31, 2008 | 03:08 AM
GM Man's Avatar
Car: 1986 2.8 Camaro
Engine: TPI 350
Transmission: Tremec TKO
So I'm trying to remove this portion of the AC/Heater box thats bolted up to the firewall, but I cant figure out how get it out. Could someone tell me what I'm missing? Is there some bolts on the engine side of the fire wall that I need to take out first?
Thanks.
Old Jan 31, 2008 | 03:53 PM
Pocket's Avatar
Car: 91 Trans Am
Re: Fixing the HVAC in my Camaro
Peel back the black sound deadening on the interior and you will see a handful of bolts
Engine side there are several
You must remove the upper housing cover and remove the dryer to get to one bolt
The hardest bolt is inline with the exhaust manifold under the heater hoses
Old Feb 1, 2008 | 02:48 AM
GM Man's Avatar
Engine: TPI 350
Chit, I was hoping it wouldnt be that hard.
Thanks for the info, I'll have to get on it.
Old Feb 1, 2008 | 10:28 AM
Pocket's Avatar
Car: 91 Trans Am
Its not that bad really
Old Feb 3, 2008 | 10:29 AM
GM Man's Avatar
Engine: TPI 350
So it can be done with the motor in the car??
Old Feb 3, 2008 | 11:35 AM
Pocket's Avatar
Car: 91 Trans Am
Absolutely
Motor in and dash mostly in
Old Feb 26, 2008 | 03:49 PM
GM Man's Avatar
Engine: TPI 350
Absolutely
It seems like there is one bolt holding me up to pull the air box out, it is behind the AC condenser?
Old Feb 27, 2008 | 02:07 AM
Pocket's Avatar
Car: 91 Trans Am
Yep
1992 Trans Am
May 10, 2023 07:19 PM
Casey Meyers
Mar 2, 2016 10:46 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
Amillionoh7
Aug 7, 2015 01:24 PM
