Inside passenger handle
Old Feb 15, 2008 | 10:30 AM
noXid's Avatar
My passenger side door handle, on the inside doesn't work. It is a bother having to open the window to be able to open the passenger side door while sitting inside the car.
does anyone know how much it would be to replace this?
Old Feb 15, 2008 | 10:43 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Inside passenger handle
Welcome to TGO. Is the handle itself broken or will it pull but not open the door? If the latter, a rod may have simply come loose. Remove the door panel and have a look see. While you're there, you may as well tighten things up:
https://www.thirdgen.org/forums/body...servation.html
JamesC
Old Feb 15, 2008 | 01:40 PM
noXid's Avatar
I checked it out, and it looks as if the rod is broken.
Old Feb 20, 2008 | 10:20 PM
89CamaroLover's Avatar
Car: 89 Camaro
Engine: 305 tbi
Junkyard would probably be your best bet to find a new one, probably only a few bucks to avoid such a hassle, or you could just roll the window down and do it like the dukes.
gta892000
Aug 11, 2019 11:16 AM
Veaceonee
Sep 29, 2016 08:15 PM
LC2 TECH
Interior Parts Wanted
Jan 27, 2016 08:38 PM
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
Fronzizzle
Sep 8, 2015 12:10 PM
