speedo swap? Is this correct? HELP!!
Old Feb 18, 2008 | 11:21 PM
ez_duzzit_all's Avatar
Car: 1986 IROC-Z
Engine: '69 camaro 350/350hp
Axle/Gears: Posi 3.23
Hey guys!! Just a quick question. I have an 86 iroc with 145 speedo. When I pull the headlight switch, my volt gauge & oil gauge drop to zero and my tach pegs out. More than likely it is my circuit board on gauge cluster. I see the dual needle 85mph clusters on ebay cheaper than the 145 clusters. My question is can i simply buy the earlier cluster and swap in my 145mph speedo? And will I need to change anything else? Thanks!!
Old Feb 19, 2008 | 08:12 PM
IROCmonkey's Avatar
Car: 85 IROC
Engine: LB9
Re: speedo swap? Is this correct? HELP!!
you would be better off getting a cluster from an 85-89, with the same guage package...not an idiot light cluster. Then yes the speedo and other guages will swap right over.
Old Feb 19, 2008 | 11:13 PM
Car: 1986 IROC-Z
The cluster I have now has the idiotlights at the botom. the cluster im looking to buy looks the same except for the speedo. I am considering it because its 50 bucks cheaper than a 145mph cluster.
Old Feb 19, 2008 | 11:17 PM
KYLE87's Avatar
Car: 1987 Camaro
Engine: 5.7
look for an 85 single needle one.
Old Feb 22, 2008 | 11:19 AM
Car: 1986 IROC-Z
So I cannot take the 145 out of my bad cluster and simply put it in the other cluster?
Old Feb 22, 2008 | 03:11 PM
Titan85's Avatar
Car: 1987 Camaro SC
Engine: 305 LB9
Axle/Gears: 3:42
As far as I know, you can sway the speedo without any problems. There is nothing that I can think of that would be different since they are both 82-89 style.
Jorlain
Aug 24, 2022 05:11 PM
reiderz iroc
Aug 13, 2015 04:57 PM
mizz0313
Aug 12, 2015 06:45 AM
beachrodder
Aug 7, 2015 04:27 PM
