Adhesive & sealer removal
Old Mar 4, 2008 | 08:58 AM
tpiselli's Avatar
Car: 83 T/A, 83 S.C., 86 S.C. & IROC
Engine: 305 CFI &TPI
Transmission: 4L60E, 700R4
Axle/Gears: 3.23, 2.73
Hi folks,
I recently pulled the carpet and padding out of my car and was wondering what everyone is doing to remove the black adhesive squares that held the carpet as well as the seam sealers. Much of the seam sealers have crumbled and come loose on their own but some of is still intact. Those black adhesive squares look like a lot of trouble and I'd appreciate some tips for getting things cleaned up.
Thanks.
Old Mar 4, 2008 | 09:37 AM
bb87camaro's Avatar
Re: Adhesive & sealer removal
I had to get the glue pads off the floor of my 87 so I could weld in the sub frame connectors.I used a rubber mallet and a stiff paint scraper to chisel it off.If you just take a little strip at a time,about 1/2 inch.It comes off hard when it's thick but once you get the thick part off the rest comes off pretty easy with the scraper.
Old Mar 4, 2008 | 12:01 PM
tpiselli's Avatar
Did it pull any of the underlying paint off the floor with this method?
Thanks,
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
ctoledo0834
Sep 18, 2015 04:16 PM
Stroopwafel
Sep 11, 2015 06:38 AM
