steer colum swap problems
Old Mar 28, 2008 | 08:36 PM
jay_d's Avatar
Car: 84 z28
Engine: 355
Transmission: TH350
Axle/Gears: one wheel peel
recently did a steering colum swap on my 83 z28 with a colum from a 86 v6 car, all the plugs seemed the same but now my headlights wont work........the two small plugs that go on the side dont have anything to do with the headlights not working do they? obvisously they work the dimmer switch but they should still come on shouldnt they?
Old Mar 29, 2008 | 05:53 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Re: steer colum swap problems
I would suspect something with the high/low beam switch. If everything is plugged in correctly, it might be worth swapping your old switch in.
Jorlain
Aug 24, 2022 05:11 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
nuggie
Aug 25, 2015 01:27 PM
sreZ28
Aug 14, 2015 07:48 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
