88 GTA gauges in 88 Camaro
Car: 85 IROC
Engine: LB9
Re: 88 GTA gauges in 88 Camaro
In a nutshell, no. You would have to swap pretty much the entire dash assembly (and the console, so it fits right). and convert the speedometer input from mechanical to electrical.
Can it be done, yes. But not easily.
Car: 1991 Z28 convertible
Transmission: TH-700R4
Axle/Gears: 3.73 posi 4th gen 10-bolt
You will have to swap the whole dash, however if you use a pre-85 Firebird cluster, you can use the mechanical speedo. Firebirds went to an electrical setup in either 85 or 86.
Ghettobird52
Jul 5, 2024 11:18 PM
