1989 Firebird Center console
Old Apr 13, 2008 | 04:02 PM
yjpep's Avatar
How do I get this thing out?
I have removed the two screws inside the console towards the rear, and I have removed the two screws in the shifter plate.
I don't see anymore screws to remove.
I don't just want to start pulling on stuff with out knowing what I am doing.
Any help would be great.
Old Apr 13, 2008 | 10:01 PM
yjpep's Avatar
Re: 1989 Firebird Center console
Got it!
Did a search for "shifter plate removal" and found some good pics of the pressure clips on the shifter plate.
Once I got the shifter plate out, everything was pretty straight forward.
Old Apr 15, 2008 | 08:42 PM
tavert91's Avatar
Car: 91 Trans Am Convertible
Engine: LB9 5.0 TPI
Transmission: 5 SPD
Axle/Gears: Posi Rear
I took my cosole out a few years ago to replace the carpet. If I remember correctly, you need to take out the two screws under the front lip of the lid just back of the mirror and window switches. That releases the top cover and exposes other hardware pieces that mount the console to the floor board. Its been a while but I think that will get it loose. There may also be another hold down screw in the front end of the same panel by the ashtray.
Glowsock
Jul 24, 2025 03:15 PM
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
DonW
Aug 24, 2015 08:24 PM
Firebird sweden
Aug 16, 2015 05:02 PM
