Odd interior light question + more
Old Apr 22, 2008 | 05:33 PM
VonKaiser's Avatar
Car: 13 Ford Focus SE / 90 Camaro RS
Engine: 122 I4 / 305 V8
Transmission: DCT / 700R4
Axle/Gears: 3.895 / 2.73
What the hell is that light under the air vents for? It emits a very dim yellow light.
Also, I need the bulb part numbers for it and the following:
  • console bulb(s) (more than 1?)
  • side markers
  • small side bulbs in tail light assy
  • hood
  • 4th gen rearview mirror
  • inside instrument cluster?
  • under dash lights (and where they are?)
  • wierd light under the top portion of the dash vents (*pic above)
I'm going to be replacing all of these lights with proper non-ricr LEDs. Thanks in advance.
Old Apr 22, 2008 | 07:06 PM
compuwiz1937's Avatar
Car: 2012 Corvette
Engine: LS3
Transmission: TR6060
Re: Odd interior light question + more
No one knows what that light is for. I'm surprised yours works, mine doesn't do anything.
www.sylvania.com and a replacement guide that will tell you all the bulbs you need.
Old Apr 22, 2008 | 07:46 PM
titan's Avatar
Car: 1990 Camaro RS
Engine: L03 305 TBI
Looking at some of my wiring diagrams it looks like it's commonly referred to as a map light.
Old Apr 22, 2008 | 08:32 PM
VonKaiser's Avatar
Amazing that it works considering the age of the car. Its never been replaced either...I didn't even know the bastard was there until 2002 when I installed that blue switch. I thought "WTF"?
A map light would sort of make sense...but wouldn't it need to be a touch brigher? *edit* But the "map light" is in the rearview mirrors...so that can't be what it is.
*edit*
So here's the list, I had no idea that they'd put the entire list in an easy to copy/paste manner.
1990 CHEVROLET Camaro
Low beam headlamp
H4656
H4656ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
H4656XV XtraVision Halogen - The Brighter Light
H4656CB Cool Blue Halogen - The Whiter Light
H4656LL Long Life Halogen Upgrade: Lasts 6x longer
High beam headlamp
H4651
H4651ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
H4651CB Cool Blue Halogen - The Whiter Light
Parking light
2057
2057LL Long Life Upgrade: Up to twice the life of the standard lamp
Front turn signal
2057
Rear turn signal
2057
Tail light
2057
Stop light
2057
High mount stop light
577
891
Fog/Driving light
885
License plate
194
194LL Long Life Upgrade: Up to twice the life of the standard lamp
Back up light
1156
1156LL Long Life Upgrade: Up to twice the life of the standard lamp
Front sidemarker
194
Rear sidemarker
194
Glove box
194
Map light
211-2
Dome light
211-2
Step/Courtesy light
168
168LL Long Life Upgrade: Up to twice the life of the standard lamp
194
194
Trunk/Cargo area
168
Under hood light
93
Instrument-general
158
194
37
Hi-beam indicator
158
Seat belt indicator
158
Brake warning
158
Automatic transmission indicator
37
Directional signal indicator
158
Old Apr 25, 2008 | 09:11 PM
Iroctopless's Avatar
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
Check out my post in this topic. I explain what it is and have a few pics of it in my car.
https://www.thirdgen.org/forums/inte...sh-behind.html
Last edited by Iroctopless; Apr 25, 2008 at 09:23 PM. Reason: trying to get the link to work
Old May 7, 2008 | 07:17 PM
92purplehaze's Avatar
Car: 90 IROC-Z
Engine: Lsa
Transmission: M6
Axle/Gears: 9" spooled 3.70
its a dope scope
Old Mar 3, 2009 | 04:06 PM
MY87LT's Avatar
Car: 1987 Camaro LT
Engine: LG4 w/ SLP headers & a 3" catback
Transmission: THM700R4 (Stock)
Axle/Gears: Stock 2.73 gears. No Posi
Console light. There is a thread "Light Above HVAC Controls" that has a ton of info and conversions to L.E.D.
Old Mar 3, 2009 | 04:09 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
dang this light is popular, WTF i knew mine was there from the first time i drove it at night ???!!!!!????
Old Mar 3, 2009 | 04:19 PM
TheMuskr's Avatar
Car: 89 IROC Z28 Vert
I have always wondered what that was
Old Mar 3, 2009 | 06:41 PM
87_Injected's Avatar
Car: 2010 2LT RS
Hmm. Now I have to go out and see if I have it in my 87!
Old Mar 3, 2009 | 06:51 PM
Car: 2010 2LT RS
Well I just checked and what did I find? I have the light too and it works! Flipped the headlight **** on and it shines! Nice to know I don't need to replace that bulb.
Old Jun 18, 2009 | 03:39 PM
MY87LT's Avatar
Car: 1987 Camaro LT
#74 replacement bulb. and you can get an l.e.d. version of it too.
Old Jun 18, 2009 | 03:54 PM
92 Camaro's Avatar
Car: 1992 Camaro RS, 66 Mustang, 78 t/a
Engine: 5.0 TBI, 289, 400
Transmission: 700R4, C4, th350
good spot for a mini shiftlight
Old Jun 19, 2009 | 06:23 PM
Guy In A 90 RS's Avatar
Car: 1990 Camaro RS
Engine: 3.1 V6 MFI
Transmission: MD8 Hydra-Matic 4L60
Axle/Gears: Standard/3.23
lol. . . I remembered reading these threads while scrounging around Pick-N-Pull for for a replacement door from attempted theft damage. I had wondered what the gaping hole was underneath my dash was (someone had removed the entire unit) and came across a gutted 91-92 RS while at the yard. Found the mount on the dash then traced through the remains of the wiring harness and found the light intact. Got home, put it all in and whaddya know, it stilled worked. But, like many others, its pretty dim.
So, how do you change the bulb out or clean it??? Seemed like a self-contained unit to me.
Seems like there's a difference in the mounts- pre-90 bolts into place, 90 and up snaps into place.
Old Jun 19, 2009 | 07:27 PM
Stephen's Avatar
Car: 87 GTA
13 months after the first Post & 9 months after the last Post, you Reply.
I take it nobody ever looks at Post dates.......
Old Jun 19, 2009 | 07:54 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
If the info is pertinent, regardless of the intervening timeframe, most thirdgenners will appreciate the post(s).
JamesC
Old Jun 19, 2009 | 07:55 PM
92 Camaro's Avatar
it's a type 74 bulb?
Old Jun 19, 2009 | 08:32 PM
Stephen's Avatar
Car: 87 GTA
JamesC
Yes.....I realize that.
But when the question already been answered numerous times in the thread.....Why add another response? Not like the question was left unanswered.
Old Jun 19, 2009 | 09:20 PM
JamesC's Avatar
Excellent.
JamesC
Old Jun 20, 2009 | 05:29 AM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
It happens all of the time..
Old Jun 20, 2009 | 03:58 PM
ThePain's Avatar
Car: 1992 RS
Transmission: Automatic
Man......... I found it was excited!! Until I realized there was a ****ing hole there.........................and i could see through my car........daylight...........and my windshield wiper!!!!!!!!!!!!!!1
Old Jun 24, 2009 | 01:18 PM
MY87LT's Avatar
Car: 1987 Camaro LT
Yes, #74 and you can get one at AutoZone, Kragen or mail order L.E.D. version with the same number.
BRoss99
Aug 10, 2025 05:08 PM
Vintageracer
Jan 10, 2020 05:33 PM
The_Phoenix
Feb 4, 2016 07:10 AM
redmaroz
Aug 16, 2015 11:40 PM
Omega
Aug 10, 2015 12:46 PM
