Windows...
Old Jun 22, 2009 | 11:55 PM
Chevy8588's Avatar
Car: 1987 Iroc Z28/ 1982 Z28
Engine: 355 TPI IP/ 305 CFI
Transmission: T-56/ 300C
Axle/Gears: 3.42 Open/ 3.73 Posi
Windows...
got a busted passenger side window, anyone know how to replace them?
Old Jun 24, 2009 | 04:06 PM
l_dis_travlr's Avatar
Car: 90 Formula -- tot resto in progress
Transmission: 700R4 w/ 2500 stall, by Owen @ ARD
Axle/Gears: 3.23 posi disc
Re: Windows...
CAREFULLY...
Necessary removal to expose the window regulator.
-- arm rest: look for large phillips screws on the underside
-- windo crank, if manual: check out another thread in this
forum about that, using specific tool, or a rag.
-- upholstery panel: these are secured w/ push-in tabs.
slip a putty-knife between panel & door, then move
up/down to find a tab. When you do, gently twist knife.
Very likely will have to replace tabs, which can usually be
found at good parts stores.
-- there may be some kind of insulating sheet stuck on the
door frame. Usually not savable, but can be replaced
with plastic sheething (from Lowe's/H-D, get the thick
lawn/gargen stuff) and metallic duct tape.
This should expose how the window is secured into the regulator.
You'll probably have to move it up/down to get to the fastening
bolts. It will probably help if you have the replacement unit in
hand to see what needs to be unfastened. And be prepared to
find some assistance, cause the glass can be very heavy for
one pair of hands to manipulate while bolting/unbolting.
There, easy as pie...
Stalker7d7
Aug 21, 2016 02:44 PM
mrfrankmrfrank
Members Camaros
45
Aug 11, 2011 12:17 PM
92RS_T-Top
Members Camaros
Dec 31, 2010 12:13 PM
ChillPhatCat
Aug 29, 2001 01:23 PM
