Headliner replacement...how do I take it out???
Old May 6, 2008 | 05:14 PM
Jammin'Trey's Avatar
Hey I need to take the headliner board (hardtop 86 firebird) out. My dome light doesn't have screws, it has these little clips that retain it up. I thought I would have to break them to pull off the dome light? Also do I have to take off any of the upper door trim molding? I know to take off the upper rear trim molding and the visors, dome light. But is that it. Someone told me there might be velcor on the front and back of it too. (no biggie).
Thanks in advance, Trey.
Old May 7, 2008 | 09:46 AM
Fyrstorm's Avatar
Car: 86 Trans Am
Engine: 385 Fast Burn
Transmission: 700R4 - stock (eep!)
Axle/Gears: Stock, will upgrade at some point
Re: Headliner replacement...how do I take it out???
That clip will slide off the post if you wiggle it down, think I used pliers to get mine off.
The trim has to come off the A-Pillar (plastic on both sides of windshield).
It's best to open your tailgate and take it out that way without bending. There are 3 or 4 clips on the front of the headliner at the windshield. After the headliner is loose you have to slide the entire headliner towards the passenger side and it should drop down.
Don't force anything hehe, it's easily bent/torn.
After it's out, do a search for headliner repair. There's tons of techniques you can use. I've yet to get mine back in hehe!
Old May 7, 2008 | 09:34 PM
green92's Avatar
Car: 92 RS
Axle/Gears: 3.08
I believe in the tech section there is an entire article on how to remove it.
Old May 8, 2008 | 02:39 PM
Manovox's Avatar
Car: 89 RS Camaro
Engine: 350 ci
Axle/Gears: 3:42
mine was removed today and was very easy! 25 mins job!! be sure to get it out from the hatch!! be sure of the front clips near the windscreen!!
Old May 12, 2008 | 06:19 PM
darksidesword's Avatar
i need help 1989 t-top Headliner
can u tell me where do i but it cheap mine got messed up so i took it out do u know any sites or place i can but it like the plastic one
Old May 13, 2008 | 01:13 AM
Manovox's Avatar
Car: 89 RS Camaro
Engine: 350 ci
Axle/Gears: 3:42
Re: i need help 1989 t-top Headliner
it depends were you live!!
because its difficult to ship as it havs to packed in a large box!!
if you search ebay or the homepage of this site you will see sponsors and click on them were you can find for sale
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
PurelyPMD
May 5, 2016 04:57 PM
formula00ra
Interior Parts Wanted
Sep 28, 2015 11:50 AM
MORREALE5
Sep 13, 2015 09:01 PM
blackbmagic
Sep 8, 2015 10:36 PM
