Will these panels fit my door?
Old May 16, 2008 | 12:48 AM
FireDemonSiC's Avatar
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
I own an 85 Z28, and I found a nice looking set of panels. But the guy is saying they will fit an 87 - 92, but I thought the panels for all the F-bodies 82 - 92 were universal
Old May 16, 2008 | 01:20 AM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
Re: Will these panels fit my door?
they aren't all universal. do the holes in your door panel line up with this one? thats the main thing, the mounting is all the same... maybe someone else will let you know exactly about the compatible years and models...
Old May 16, 2008 | 07:15 AM
mpb74's Avatar
Car: 1986 Iroc-Z
Engine: 355 Phase 2 Bowtie heads
Axle/Gears: 342
i believe the 88-92 cars were a little longer but i think that was mostly in the front and back bumper covers. that panel should fit. i have a door from 1988 on my 1986 iroc,and i have the 1986 door panel on the 1988 door. fits like a glove.
Old May 16, 2008 | 07:36 AM
dfarmercse's Avatar
Car: 83 Camaro Z28
Transmission: 700R
The door panels are the same in shape and size. The carpet is different on early cars. My 83 the carpet is not angled up like the door panel you show. The early cars the capet was straight across the door panel.
Old May 16, 2008 | 12:26 PM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
Those door panels will fit any thirdgen...all doors were the same size as well therefore the door panels will fit...
Old May 16, 2008 | 04:02 PM
gordo420's Avatar
Car: 89 RS Camaro
Engine: 355ci.
Axle/Gears: 373:1
I just picked up a set of door panels just like those for my '89 RS I got them from a boneyard here locally for $15 for both out of a '91 RS.
your panels should fit without any problems
1992 Trans Am
May 10, 2023 07:19 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
