Tightening Dash Pad?
Old May 16, 2008 | 09:34 PM
88_CC1_IROC's Avatar
The dash pad on my car is loose. I've looked around it a little bit to see how it is attached, but am still puzzled. When I'm on the freeway the whole thing wiggles up and down. Any way to fix it?
Old May 17, 2008 | 05:25 PM
yankeecarman's Avatar
Car: 1991 Trans Am convertible
Re: Tightening Dash Pad?
Take it off and have a look on the backside and make sure the holes have not opened up. If they have, you can add to them and make the screws hold better. Only four screws on the front of the pad and about 6-7 on the nearest side under the lip of the pad. Should be easy fix.
Old May 18, 2008 | 02:19 PM
Cool. Thanks!
Old May 18, 2008 | 08:36 PM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Are you sure its not the whole dash assembly bouncing around? My cars do that... Like there isnt enough support in the middle of the dash. But its my entire dash...not just the pad.
Im going to build some supports while Im working on mine. Just some simple round bar braces should fix it up.
J.
Old May 19, 2008 | 09:41 PM
The dash itself is solid, so I'm assuming it's just the pad on top.
Old May 24, 2008 | 01:16 PM
ATX-Iroc's Avatar
Car: 87 Iroc-Z
Engine: 305 tpi
Transmission: 700-r4
My car does this to. take off the dash pad and look at supports close to the out side edges. Mines broke and sounds like yours are too.
Old May 25, 2008 | 10:11 PM
samiam91RS's Avatar
Car: 91 RS
Axle/Gears: 3.45
either get more screws to hold it down, or take the dash pad off and check underneath to see if you still have those foamy supports that go underneath it to keep it snugly in place. also, there are screw holes that go ontop, where the vents are, and underneath along the whole lip. theres like 14 screws all together. ive taken mine on and off to replace the font speakers and also got a newer one with no cracks and mine is always nice and snug.
PurelyPMD
May 5, 2016 04:57 PM
Billgluckman
Members Camaros
36
Nov 24, 2015 07:29 PM
FED 387
Interior Parts Wanted
Oct 10, 2015 01:43 PM
codeysabatini
Sep 20, 2015 11:36 AM
Stryker412
Sep 7, 2015 09:11 AM
