T-top head liner
Old May 26, 2008 | 10:19 AM
jts87iroc's Avatar
Car: 87 iroc
Engine: 305 tpi
Transmission: 4sp auto
T-top head liner
i removed my head liner to recover it. found it has a crack it it and droops on the driver side what is the best way to reinforce the head liner so it wont break in two. and recover with new felt ? thanks
Old May 26, 2008 | 02:33 PM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
Re: T-top head liner
The first t-top headliner I removed broke into 2 peices right in the middle and I used fiberglass cloth to put it back together with some 3m spray addhesive both for the fibergalss cloth and for the fabric.
Old May 26, 2008 | 05:17 PM
jts87iroc's Avatar
Car: 87 iroc
Engine: 305 tpi
i'll try that
Old Jun 5, 2008 | 08:37 PM
jts87iroc's Avatar
Car: 87 iroc
Engine: 305 tpi
how do you get the inside corners to cover right? i cant seem to get it in the corners and stay? the foam is to tight to get in the corner. any pics on how to cut it right?
Old Jun 6, 2008 | 09:56 AM
NoMoFoMoCo's Avatar
No pics, but you want to do a tab type thing, so its not jsut one cut on the corner, but a few cuts. So that way you can get the cloth fto fold over and not need to stretch to adhere. I can do a image to demonstrate if need be.
Old Jun 6, 2008 | 10:17 AM
TireSmokin''s Avatar
Use pie cuts for any inside and outside radius. If it's a compound radius, no cuts should be necessary.
BlueIroc-Z
Jun 9, 2019 03:22 AM
gta90
Sep 15, 2015 04:00 PM
1Aauto
Sponsored Vendors
Aug 26, 2015 02:14 PM
qz6lwp
Aug 20, 2015 08:10 PM
