need help with cluster swap
Old Jun 21, 2008 | 03:56 PM
DeadHooker86's Avatar
Car: 86 Camaro IROC Clone
Engine: 2.8L Fuel Injected V6
Transmission: Automatic
so what i want to do is swap the guage cluster in my 86 for one from a 91. can somebody give me an outline of what to do, i cant stand the dummy lights anymore and i want real guages. im pretty much clueless on where to start, or even if it can be done. will all the new guages plug up to the old wires or will i have to rerun new everything?
also does anyone know whats causing my cam & crank sensors to turn on the check engine light? if they were broken the car wouldnt move right, so maybe they shook loose or something?
Old Jun 21, 2008 | 06:10 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: need help with cluster swap
The swap would require a major modification since the clusters aren't the same ( 82-89 have mechanical speedos, 90+ electric.). You can, however, sway gauges into your car. Check the FAQ's.
JamesC
Old Jun 23, 2008 | 05:56 PM
i didnt see anything about it in the faq's
Old Jun 23, 2008 | 09:07 PM
JamesC's Avatar
My bad, tech articles:
https://www.thirdgen.org/gauges
JamesC
Old Jun 23, 2008 | 09:27 PM
cdoyle's Avatar
I did this swap in my 84, and I was surprised how easy it was.
I swapped out the entire dash, you'll need to move some pins around on the firewall harness C-100, and I believe a few wires on C-200 (I can't remember if that's the right number) It's the harness that hooks to the computer.
You'll need to find the schematics for both cars, and just move the 91 harness to match the other side of the 86 harness.
As for the speedo, I just got a used sending unit off a junk car and swapped out the mechanical one. and ran the wires up.
Do a search under my name, I have a thread on here somewhere on the whole process.
Jeremys87
Jul 14, 2022 09:08 PM
Eric2ndGen
Nov 5, 2015 01:51 PM
Bstrang6
Sep 8, 2015 04:29 PM
355sbcTPI
Aug 19, 2015 04:38 PM
ChevyZ71
Aug 13, 2015 07:30 AM
