want to change my sterring wheel
Old Jun 26, 2008 | 11:05 PM
jakekempf1990's Avatar
Car: 1992 z28,1992 rs
Engine: 5.7 tpi, 383
Transmission: 700r4,700r4
Axle/Gears: 3.73 posi , 327 posi
hi i would like to know if i can change my steering wheel in my 92 rs to a eariler style z28 wheel
i would like to change it to the eariler z28 wheels like my dads 86 irocz
Old Jun 27, 2008 | 12:12 AM
31BiRd92's Avatar
Car: '92 BiRd
Engine: 3.1L
Transmission: auto
Re: want to change my sterring wheel
If yours is identical to mine(which it should be), you will have to change your wires a little bit and remove the air bag wire completely. Thats what I had to do in order to use my Grant wheel.
Old Jun 27, 2008 | 12:14 AM
thanks
is it a easy job?
Old Jun 27, 2008 | 11:01 AM
31BiRd92's Avatar
Car: '92 BiRd
Engine: 3.1L
Transmission: auto
Yeah its pretty much straight forward. its not too hard. you'll have to merge your 2 horn buttons into 1 and get rid of an air bag wire thats all. then just put the new wheel on and run your wire. you may also want to remove your airbag light from the dash. I havent yet started my car but I imagine the light wouldnt go off seeing as it isnt there anymore. However, I wont even pretend that i know this for sure b/c I've never taken an air bag wheel off before now, so its just a guess.
Amillionoh7
May 24, 2020 08:01 AM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
z28_AJ
Aug 27, 2015 08:59 PM
forstral
Aug 19, 2015 03:20 PM
kah992
Aug 19, 2015 02:55 PM
