Will the top part of the dash from a firebird fit in a camaro?
Old Jul 3, 2008 | 10:11 PM
FirstLove1991RS's Avatar
Car: Building a 1984 Z28
Engine: 383
Axle/Gears: Posi Discs
I have a 1991 firebird dash, the top black part, will it fit into a camaro? thanks
Old Jul 4, 2008 | 12:09 AM
BrOdBaNd's Avatar
Car: 92 Camaro
Engine: El Tee Juan
Transmission: Tee five six
Axle/Gears: 10 Bolt 4:10's
Re: Will the top part of the dash from a firebird fit in a camaro?
Im not sure if it will fit right. The center vents on the camaros stuck out a little farther and the camaro dash pads actually had a lip to incorporate into the vents. The firebirds didn't have that center vent.
Old Jul 4, 2008 | 12:37 AM
Stephen's Avatar
Car: 87 GTA
What center vent are you referring to? My GTA, as well as EVERY dash pad I've seen, has them. The only dofference I've ever seen is the 2 small vents for blowing on the door glass.
But, as I understand, there is about a small difference in depth, front to back. Meaning, a Firebird one will fit to the glass, but not reach the hold-down screws. Or starting at the screws, not reach the glass.
Old Jul 4, 2008 | 03:29 AM
BrOdBaNd's Avatar
Car: 92 Camaro
Engine: El Tee Juan
Im referring to the center dash lip that goes over the vents. If you look in the pic you can see it circled in yellow. I dont know if it would work right if you used a firebird dash because I didn't think they had that lip?
Attached Thumbnails Will the top part of the dash from a firebird fit in a camaro?-92z28interior.jpg
Old Jul 4, 2008 | 10:36 AM
Stephen's Avatar
Car: 87 GTA
Oh...Birds have the vents, but not that lip.
Old Jul 6, 2008 | 02:19 AM
MillerTime21's Avatar
Car: 94 25th TA
Engine: 355LT1
Axle/Gears: 10bolt 3.42
No, I attempted to put a dash pad from a 91 firebird into my 88 Camaro. I forget exactly why it wouldn't work, but it was off a little in size and the screw to hold it down didn't line up.
Old Jul 6, 2008 | 11:51 AM
Iroctopless's Avatar
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
Yeah, if your referring to swapping the dash pads, it won't work. The corners are quite different and it won't sit or line-up properly.
Old Jul 9, 2008 | 10:56 PM
Engine: 383
ok thanks u guys
Old Aug 21, 2008 | 10:47 AM
hotdaddysturn's Avatar
Car: 91 firebird
Transmission: auto with o/d
i need a good dash pad for my 91 firebird
Old Aug 21, 2008 | 10:52 AM
Stephen's Avatar
Car: 87 GTA
Try looking or posting in the Wanted Forum, not here, and you might find one.
Old Aug 22, 2008 | 06:50 AM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
PM RCAR7395 in the " parts for sale" forums He can usually get some really good ones....
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
armybyrd
Aug 10, 2015 09:23 PM
1nastygta
Aug 8, 2015 07:38 PM
