rear shade mounts
Old Jul 4, 2008 | 01:24 PM
AngryBird's Avatar
Car: 1989 GTA
Engine: TPI 350
Axle/Gears: stock axle
rear shade mounts
Whats up everyone! I have a quick question. I am mounting a rear cargo shade in my car that did not have one before. The mounts are slightly different on the back. One has one notch the other has two. Does it matter what side of the car I put them on?
Thanx
Jesse
Old Jul 4, 2008 | 01:53 PM
lordmetalz28's Avatar
Car: 1987 Z28 with iroc-z Package no.3
Engine: 350TPI
Axle/Gears: 3.73 posi
Re: rear shade mounts
i dont think it does if where on the same topic. the side with the one pin or mount you can pull back to release the shade assembly correct??? i know that you have to have that handle upwards inorder to latch it to you hatch trim panel properly.
Old Jul 4, 2008 | 02:09 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
the interior panels have the template for the mounts formed onto the back of the panel, check them out and see if one is different than the other
Vintageracer
Jan 10, 2020 05:33 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
lee01
Apr 9, 2016 01:56 PM
