horn problem please read
Old Jul 11, 2008 | 08:21 PM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
recently when i turn my wheel to the left at one dead spot whenever i pass it my horn goes off/turns on. if i keep turning it turns off and when i turn back pass that one point horn goes off/turns on.
so stupid
what part would be shorting/grounding the horn?
even does it when the horn button is off so its something deeper/internal
Old Jul 11, 2008 | 08:40 PM
alicat's Avatar
Car: 1985 z28 camaro
Engine: 305 lg4,edelbrock,3"air cleaner.k&n
Transmission: turbo 700r4 w/b&m megashifter
Axle/Gears: Stock.
Re: horn problem please read
Mine was doing that.Happened after some work on the steering coloum,so i think its a pinched wire down there somewhere.I have'nt had a chance to have a look yet.I've just got it disconnected.
Old Jul 11, 2008 | 08:42 PM
Bobby_80s's Avatar
Axle/Gears: no idea
i see, anyone else have a problem like ours? any solution? im going to take the darn thing apart on my day off next week but its just one of those problems that is just sooo stupid just is agrivating because i dont feel like taking apart my steering columb and mess with the turn signal housing but i guess i have no choice
Old Jul 11, 2008 | 08:48 PM
alicat's Avatar
Axle/Gears: Stock.
First have a look where the coloum harness goes down underneath,look for the simple areas first.Always easier than pulling everything apart.
Old Jul 11, 2008 | 09:56 PM
Bobby_80s's Avatar
Axle/Gears: no idea
well its gota be somewhere on top. i would think. somewhere between the turn signal switch and the steering wheel. nothing i can do but take that apart to fix it
it only honks when i turn the wheel on a certain spot
Old Jul 14, 2008 | 11:42 AM
TZFBird's Avatar
Car: 1988 Firebird, 2000 GTP
Engine: 327
Axle/Gears: 9" posi, 4.11
There is a spring loaded contact in there. If you are getting some bind that is causing that spring to collapse, or the contact to jump around that could happen. Or the spring is broken.
I'm trying to remember, but 12v comes from that spring loaded rotary contact, then goes to the two horn buttons. Aren't there wires that run between the two buttons, then to the center of the column? So you are really just grounding the horn circuit with the buttons.
I would start by looking behind that center panel in the wheel. That is the only area you should have any movement.
I was poking around in there one day and managed to break that rotary contact so I have no horn at all now. Be sure to be careful with that part.
Old Jul 14, 2008 | 12:39 PM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Axle/Gears: 3.55 Wavetrac
The rotary contact part is in the "HELP" product line at the auto parts stores. Cost about 6-8 bucks.
Ghettobird52
Jul 5, 2024 11:18 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
wayshegoes
Aug 17, 2015 12:00 PM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
