3rd gen back seats and 4 gen back seats
Old Jul 17, 2008 | 06:30 PM
87transam_93003's Avatar
ok my T/A has 4 gen front seats and 3rd gen back seats i want to get seat covers but dont want to buy 2 pairs does anyone know if the 3 gen back seats are the same size as the 4 gen one?
Old Jul 17, 2008 | 06:39 PM
black89ws6's Avatar
Car: 89 Formula, WS6
Engine: LB9/peanut cam :(
Re: 3rd gen back seats and 4 gen back seats
I think so. 4th gen seats in 3rd gen interior is a fairly common swap. I've got 4th gen leather seats in my car, front and rear, and they look the exact same size as thirdgen seats.
The only thing I think you need to look out for is the folding rear seat to match, whether you have the split folding rear seat, or the single folding rear.
Old Jul 17, 2008 | 07:33 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Just installed a set 4th Gen set in my '86 Z28, the rears are practically the same size....
Old Jul 17, 2008 | 07:43 PM
Stephen's Avatar
Car: 87 GTA
4th gens didn't ever get the split rears. That has nothing to do with the original post...Just wanted to pass that on, for those who weren't sure.
As for the 4th gen fabric fitting the rear cushions...The 4th gen rear seat bottom cushions are a BIT narrower. Those who have 4tn gen rears, will notice that the bottom cushions seem to be narrower & not fill out the space fully. Hardly noticeable unless you really look, but they are narrower.
That being said...The 4th gen fabric MIGHT fit, but need to be stretched a little tighter to fit a 3rd gen cushion. I seriously doubtthat it WON'T fit. I'm pretty sure it will. Just tighter & require a bit more effort. For that matter, maybe you could slice an edge off the 3rd gen cushions, but I'd try fitting the fabric first. Cut too much off & it would fit bad. Better tight than loose.
Old Jul 17, 2008 | 08:00 PM
Originally Posted by Stephen
4th gens didn't ever get the split rears. That has nothing to do with the original post...Just wanted to pass that on, for those who weren't sure....
At first I was like what the heck is he talking about, but I just realized you were referring to the post before mine lol. Yes, the 4th gen bottom cushions are slightly narrower, but I'm sure the covers would still fit by stretching them, as you pointed out....
Old Jul 17, 2008 | 08:50 PM
thanks for the info this is a gr8 site!
Old Jul 18, 2008 | 09:05 PM
Iroctopless's Avatar
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
I never knew that. I wonder if 4th gen owners have ever modded their rides with 3rd gen splits (recovered to match the front and hinge points added, etc)? Maybe they are to wide (could just use the frames and change the foam I guess).
Old Jul 18, 2008 | 09:09 PM
Stephen's Avatar
Car: 87 GTA
If the car didn't iriginally have the split rears, it wouldn't have the middle 2 pivot mounts for the bottom of the seat backs. And, if IIRC those 2 pivots are spot welded brackets, not just bolted in, so they wouldn't be simple to transplant.
Old Jul 18, 2008 | 09:13 PM
black89ws6's Avatar
It is not hard to remove them if you have a spot weld cutter. Takes about 10 minutes. When installing in a new car, just drill bolt holes through the hole left by the spot weld cutter, or MIG it.
Old Jul 18, 2008 | 09:20 PM
Axle/Gears: 3.08
. . . and hinge points added, etc
Yeah, I know it would take some work, but not impossible. I was just kind'a curious.
colton_carlson
Mar 8, 2019 12:21 PM
Fast355
Dec 2, 2016 06:33 PM
Omega
Oct 1, 2015 02:20 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
