Autometer gauges in my Bird
Old Jul 31, 2008 | 07:18 AM
Meatman's Avatar
Car: 1988 Formula
Engine: 355
Transmission: 6 speed
Thought I would share. Lot of work, but oh so worth it.
Old Jul 31, 2008 | 07:21 AM
JCoca's Avatar
Re: Autometer gauges in my Bird
Looks awesome! Awesome work!
Old Jul 31, 2008 | 10:31 AM
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
My gauges are starting to go, so I was thinking about getting some newer ones. I like the look of Autometer but not the price tag. So, how much did it cost and what did you all have to do? I assume you had to make a new backing thing out of ABS plastic and had to drill the new holes and everything. Where can you get ABS plastic?
</div>
Old Jul 31, 2008 | 10:39 PM
Meatman's Avatar
Car: 1988 Formula
Engine: 355
Cost about $550 for Phantoms and I bought the universal summit shift light. I just used plexiglass. It was really easy to work with.
Old Aug 1, 2008 | 07:39 AM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
Looks really good. Did you have to modify the stock cluster panel very much before attaching the plexi? Also, where did you end up getting the high bean/turn signal indicators from?
Old Aug 1, 2008 | 08:35 AM
87_GTA_5.7's Avatar
Car: 1987 Pontiac GTA Trans Am
Engine: Basic Stroked SBC..383
Transmission: PerformaBuilt 700R4 3000 Stall
Axle/Gears: Moser 9in. 3:70s
Whats the part # on that speedo? Also did you use 2 1/6 for the 2 5/8s? I like the look of the sizes you used. Iv been thinking about doing that with the Ultra Lite style. Looks kick *** btw!
Old Aug 1, 2008 | 07:40 PM
Meatman's Avatar
Car: 1988 Formula
Engine: 355
Ya I had to cut a decent amount out of the stock cluster to get them to fit. The tach and speedo are 5" and the rest are 2 1/16"
The turn signals and high beam LEDs I got from summit. The part #s are
ATM-5714 Fuel
ATM-5727 Oil
ATM-5737 Water
ATM-5791 Volts
ATM-5889 Speedo
ATM-5898 Tach
The speedo is awesome. All you do to set it up is find a marked out 2 mile stretch, so I just went to mile markers on highway. Then hit button, drive the two miles, then hit button again and its set. Gravy....
Old Aug 1, 2008 | 10:52 PM
87_GTA_5.7's Avatar
What does it take to make the turn signals work? I cant find an LED that I like really. I like yours but I cant find it either.
Old Aug 2, 2008 | 11:28 PM
Meatman's Avatar
Car: 1988 Formula
Engine: 355
All I did was pull the wires I needed out of the stock harness. Everything you need is there. I just used all the stock wires for the new senders, that way I ddint have to run new wiring for all that. I found a cluster pin out on here and printed it off. Just use search.
PRF-80202 is the turn signal LEDs I bought
Old Aug 4, 2008 | 09:12 PM
91CCFirebird's Avatar
Very nice look....I need to get motivated to do mine
Old Aug 8, 2008 | 01:38 AM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
The wiring part is really easy. The only part that is a little hard is getting the panel to look just right. I painted the back of the piece I used to do my 85 T/A mettalic silver and then hit it with 2 coats of black. I used pro comp ultra lites, and the silver background looks killer. I get lots of compliments. The Gauges cost me about 1,000 bucks and the Acrylic cost me about 15.oo at Ace hardware. (1/4 inch)
Oh, hey, Meatman; What did you do about your S.E.S. Light? I put in a yellow L.E.D just below the Tach.....
Last edited by drknow90rs_ss@y; Aug 8, 2008 at 01:41 AM. Reason: Automerged Doublepost
Old Aug 14, 2008 | 01:49 PM
Meatman's Avatar
Car: 1988 Formula
Engine: 355
I did all the gauges and switched to a carb at the same time. So....no more SES light.
Old Aug 15, 2008 | 08:15 AM
einarak's Avatar
Car: Camaro RS
Engine: 327
Axle/Gears: Alloy axles, motive 3.73
really nice, I went that way to in my 89 Camaro.
along with 12v led´s for indicatorlightst (hand brake, turn signal, line lock, ect.)
Old Aug 15, 2008 | 12:36 PM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Looks alittle familiar
One of the best mods Ive done so far. LOVE LOVE LOVE the autometers.
J.
Hotrodboba400
Dec 10, 2019 07:07 PM
87v6Bird
Brakes
Oct 4, 2015 07:37 AM
90formulaVortec
Sep 8, 2015 12:42 AM
Glowsock
Sep 6, 2015 06:40 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
