dash & console plistic type ?
Car: 91 Z28
Axle/Gears: Moser 9" 3.70 35 spline wavetrack
what type of plastic is the dash and console made out of ? what about the other pieces of the interior ?
Car: Used to drive a camaro
Re: dash & console plistic type ?
Most of the interior plastic is ABS. Some ABS/PC blends but 99% is ABS. The same stuff model airplanes are made of. The dash has to be some sort of TPE high durometer material or a weird blend of polyeurethane (rubber).
Car: 91 Z28
the dash board face with the insterment cluster housing not the dash pad
The faceplate around the guages is ABS. The dash / console is ABS, the dashpad is like a polyurethane or TPE derivitive. All the black stuff in your car.......most likely ABS. Put some Testors model glue on it and if it melts....its ABS.
