Hatch won't open
Old Aug 8, 2008 | 11:43 AM
edgewood81's Avatar
Hatch won't open
I just bought a 89 RS for my son, his first car and I can not get the hatch open. I put the key in and turn it but the hatch won't open is this a electric switch and if so is there a release inside the car? Thanks in advance for any info.
Old Aug 8, 2008 | 04:05 PM
TurbomanKnight's Avatar
Car: 1983 Recaro T/A
Engine: L69
Transmission: MM5
Axle/Gears: 3:73
Re: Hatch won't open
In between the window switches (if equipt with P/W) there should be a switch there. Thats the electric release.
Old Aug 8, 2008 | 04:09 PM
crazyblue92's Avatar
on my 92 with elec hatch sometimes when i turn the key it wont open unless i give a small tug on the hatch i know mine does this because it was rear ended and the quarter pannel is rubbing the deck lid but like TurbomanKnight said the switch on the center console should have a switch.
Old Aug 8, 2008 | 06:50 PM
my82roc's Avatar
Car: 89 Iroc Convertible
If the switch doesnt work you could try pulling on the cable that attaches to the lock cylinder.You have to remove the small light that is mounted in the center rear hatch trim piece.Then stick your finger in there on the left hand side and feel for the cable that is attached to the pulldown unit.Give a tug on that and it should pop the hatch open.I have had to do this many times on junkyard 3rd gens
Old Aug 8, 2008 | 09:39 PM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
TBRays98
Sep 6, 2015 05:05 PM
luvofjah
Sep 3, 2015 07:08 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
