Ok, Just bought my 3rd F-body and have some Q's
Old Aug 14, 2008 | 10:35 AM
Wickedclown01's Avatar
Hi all First, let me say.. GREAT group here!!
Ok.. I just bought an 89 Camaro RS with Factory 305 TBI engine.
I am having some normal Camaro issues on the inside.. and wondered if there are better solutions for the problems now:
1. Windshield Washer Switch cracked - better aftermarket replacements?
2. Dimmer switch seems to be going.. working only periodically.. could be related to the WW Switch.. ideas?
3. T-Tops Leaking.. (major shock, right?) - Best aftermarket solutions?
Don't get me wrong.. the car is in immaculate condition.. just has the normal wear issues that I have always found in F-body camaros..
Old Aug 14, 2008 | 11:27 AM
mario82z28's Avatar
Car: 82' z28/03' eddie bauer explorer
Engine: 355-395hp/4.6v8
Transmission: Built 700R4/5speed auto 4x4
Axle/Gears: 3.42LSD/3.73
Re: Ok, Just bought my 3rd F-body and have some Q's
most of local part stores carry head light switches and windshield washer/turn signal switch in stock, these two parts wouldn't effect each other specially since 1 just has a crack in it as far for the t-tops if they have been leaking for a while id check for rust if non just simply change the weather striping and that should fix it
Old Aug 15, 2008 | 08:52 AM
I will go to my Autozone and check on the new parts! I just know before when I had my 82 Z28, they were not that easy to find lol.. but.. that was a *cough* couple years ago.
I have checked the t-tops, there is no rust.. it's a minor leak, hasn't been that long.
Thanks again!
Old Aug 15, 2008 | 09:26 AM
KJZ28/TA's Avatar
Car: 2002 Camaro
Engine: :(
If I were you I would not just replace the t-top gaskets. I did that and they leaked worse. I like you had a small leak. t seems that Most people only have success if they also take the t-bar off and reseal that as well. Becasue sometimes from taking the t-tops off the t-bar is loosened and will leak like a sieve.
I bought OER gaskets and they were trash...avoid them.
Old Aug 15, 2008 | 10:28 AM
Ok, so what is your suggestion for the complete T-Top fix.. and what parts should I use? I want to keep this car for a long time.. so.. any help is appreciated. Thanks
Old Aug 15, 2008 | 07:39 PM
Anthonys434's Avatar
Car: 83 Z28 Camaro
Engine: 5.3L L33
Transmission: 4L65E
Axle/Gears: GM 12 bolt 3.73
Soft Seal is the way to go for new t-top weatherstripping. I had them put in my camaro when it was getting painted. Very tight seal. JMO
Old Aug 16, 2008 | 04:30 AM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
Yeah, go with the softseal complete T-Top kit, it really works and wont break the bank too much.
Old Mar 3, 2009 | 03:53 PM
MY87LT's Avatar
Car: 1987 Camaro LT
Engine: LG4 w/ SLP headers & a 3" catback
Transmission: THM700R4 (Stock)
Axle/Gears: Stock 2.73 gears. No Posi
You can get Delco parts from Kay Automotive.
Old Mar 3, 2009 | 07:10 PM
87_Injected's Avatar
Car: 2010 2LT RS
They sell the actual switch itself? The switch with the cruise control and turn signal lever? Is this the lever we are referring to or the switch inside the column?
Old Mar 3, 2009 | 08:48 PM
I was referring to the lever with the switch activators on it.. that is what's cracked.. although I am getting a new dimmer switch as it is broke as well lol
bjpotter
Jan 22, 2019 12:27 PM
86IROC112
Sep 7, 2015 01:37 PM
neekolzun
Aug 24, 2015 04:59 PM
johanlindgren
Aug 16, 2015 12:16 AM
reiderz iroc
Aug 13, 2015 04:57 PM
