GTA Seats ... How do you get the plastic off?
Old Aug 14, 2008 | 02:30 PM
gcgarner's Avatar
Car: '92 T/A WS6 Vert/1956 Chevy Nomad
Transmission: 700r4 w/ Transgo Kit
Axle/Gears: 3.42 LSD
I am thinking of tackling the project of re-covering my GTA-style seats this afternoon if I don't make it to the track.
I got my seat covers from Hawk's ... Hampton Vinyl.
Does anybody know how to remove the plastic pieces from the seats to re-cover them? I am talking about the seat back and back of the headrest.
Thanks!
Old Aug 14, 2008 | 08:14 PM
gcgarner's Avatar
Re: GTA Seats ... How do you get the plastic off?
Anybody? I called Princess "The Cover Girl" at birdsandbowties.com, Hawk's and Young's F-Body, and nobody knew the answer to this. I need to get these seats done ASAP and I don't want to break anything.
Old Aug 16, 2008 | 03:46 PM
gcgarner's Avatar
C'mon guys ... surely somebody knows the answer to this. My car is going in a show next weekend and I would love to have my new seat covers on.
Old Jul 17, 2009 | 08:34 AM
Unholy 89's Avatar
Car: '89 5spd GTA
Engine: 305(LB9) TPI
Axle/Gears: Borg-Warner 3.42
Any answers?
Old Jul 17, 2009 | 09:36 AM
gcgarner's Avatar
I ended up taking them to an auto upholstery shop. Even the pro had trouble with them. But they look great now. Good luck!
Old Jul 17, 2009 | 10:16 AM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
Do you have an answer for us then? Are they stitched onto the fabric?
Old Jul 17, 2009 | 11:04 AM
gcgarner's Avatar
Ask my auto trim guy. Eddie Moore at Moore's Auto Trim. His number is (828) 328-1496. Tell him I had the red 92 T/A convertible there last August. I wish I could answer that for you, but I can't.
Old Jul 17, 2009 | 12:17 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
I was just curious.... but not curious enough to call him up. I thought you might've seen them do it.
Old Jul 17, 2009 | 01:27 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
A little late, but the covers are held on by screws.Top(inside the boot) & very bottom for the seatback.Cargo net, visible when seatback is removed(2 on top,2 on bttm).Head rest, remove both rubber covers from the adjuster *****, remove screws from the adjuster wheels(white).Also remove the headrest pad(i think it just pulls off).Then remove the 2-3 screws behind it.To remove the whole headrest, insert a flat piece of metal down the bar(cant remember if its on the front or back, but there is a release clip on the seat frame).Once you push in the metal piece, you can pull the headrest out.You will need to pull the boot down from under the headrest for this.
As for the seat covers.They are held on by hog rings & velcro in some areas(seat cushion for one).You will have to seperate the seatback frame from the lower seat frame to remove the covers/air hoses from the foam.
The Rr fold down has either a zipper or J-clips that snap together at the bottom.The Rr seat cushions are mostly glued in place with some hog rings along the bottom.
Its been about ten years since i last replaced these.So some details may be cloudy, but this is the majority of the work involved.
Have fun
1992 Trans Am
May 10, 2023 07:19 PM
lee01
Apr 9, 2016 01:56 PM
gta90
Sep 15, 2015 04:00 PM
MORREALE5
Sep 13, 2015 09:16 PM
scottmoyer
Interior Parts Wanted
Aug 9, 2015 10:18 PM
