turn signal lever( again)
Old Sep 1, 2008 | 04:03 PM
lordmetalz28's Avatar
Car: 1987 Z28 with iroc-z Package no.3
Engine: 350TPI
Axle/Gears: 3.73 posi
im posting this again cause i never really got a solid answer. 87 chevy camaro iroc-z need to replace the turn signal lever, lever not switch. how do i do this?? have to dismantle the column?? let me know
Old Sep 1, 2008 | 04:18 PM
JT's Avatar
JT
Community Administrator
Re: turn signal lever( again)
No, you don't need to touch the column itself if you need to replace the arm/lever. It's simply an arm/lever that actuates the switches inside the columns.
https://www.thirdgen.org/forums/post...980-post4.html
Old Sep 1, 2008 | 08:33 PM
Engine: 350TPI
so im just grabbing that lever and yanking on it till i comes or(breaks) out of the switch??? just grab and pull like a hethan??? god bless me
Old Sep 1, 2008 | 11:52 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Push in on the lever, turn counter-clockwise about 90 degrees, and it comes right out. You may have to wiggle it a little, but it does just slide out.
Old Sep 2, 2008 | 12:18 AM
Engine: 350TPI
i read your post a couple months back. i been trying that off and on with a little fear. i was worried it was maybe a rare pontiac thing. ill try again. i was just reading a haynes manual and it said the lock plate needs to come out and i need to loosen the turn signal arm screw ever hear of anything like this?
Old Sep 2, 2008 | 06:44 AM
JT's Avatar
JT
What Ward said above (and what I posted) is correct. But I'm not sure about the "Push in on the lever, turn counter-clockwise about 90 degrees" is necessary. I've never really looked at the socket ends to verify myself, but even the GM shop manuals do not mention doing that procedure. They simply state to pull the multifunction lever straight out.
What the Haynes manual appears to be describing is removing the switch itself.
You do not remove the steering wheel or parts on the column.
Old Sep 2, 2008 | 10:42 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
JT is correct, the column doesn't have to come apart just to replace the lever. I think the manual is talking about replacing the turn signal switch itself, the piece that the lever slides into. In that case, the wheel and lock plate would have to come off.
83 Crossfire TA
Jan 3, 2016 01:26 PM
bbsr72
Sep 27, 2015 05:55 AM
TrevinE
Sep 14, 2015 03:20 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
