started on 4th gen door panels...mmmmm
Old Dec 14, 2008 | 06:21 PM
  #51
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
Re: started on 4th gen door panels...mmmmm
Originally Posted by 92purplehaze
thats what i thought... come to think of it i have a pic saved of your car with the old rims on my computer because i want to paint it the same color. beautiful car btw do you have any under hood pics... or just more pics in general
here ya go.
Attached Thumbnails started on 4th gen door panels...mmmmm-dscn1987.jpg   started on 4th gen door panels...mmmmm-dscn1990.jpg
Old Dec 14, 2008 | 07:38 PM
  #52
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Hey stage... Whats the deal with that breather? What type is it and whats covering the outside? Im still trying to come up with a suitable breather set up... just curious what you have goin on there.
J.
Old Dec 14, 2008 | 10:02 PM
  #53
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
J.
its a stock truck adapter, with a universal K&N clamp on. i used a piece of pvc pipe to join the two. just a lil sanding and fighting it in. the filter will come on and off no problem.
only have about 20 bucks in the whole setup, or you could by a metco breather and accomplish the same thing. (60 bucks)
i have a heavy duty academy brand wristband on it. keeps from coating my firewall with oil mist.
they come in 2 packs pretty cheap. it starts getting brown, i just swap to a new one.
going to a breather tank setup with my new motor so it doesnt spray oil everywhere.
Old Dec 15, 2008 | 06:52 AM
  #54
Car: 86 Trans AM
Thats one of my two biggest issues with my breather set up now. Im using a universal autozone breather anda drilled out stock oil cap. However i just noticed its got oil all over the coil cover, and probably the firewall. Even though everyone over on tech claimed they didnt get oil mist...
I dont mind cleaning up alittle oil, but my BIGGEST issue is the smell. If the windows are up, and the vents are blowing hard, its hardly noticable. But as soon as I crack a window and get a draft pulling through the car, it gets pretty nasty in there. Makes my clothes stink...and my GF hates it. But I LOVE not having ANY oil in my intake...so Im going to have to resort this idea...
J.
Old Dec 15, 2008 | 05:33 PM
  #55
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
mine is nowhere near that bad. cant even smell it. thats on my stock motor though. got a 408 big head/cam going in soon, and afraid its gonna get nasty.
im going to run 2 drivers side valve covers with an fittings/hoses to a tank to try and keep the oil to a minimum.
Old Jan 3, 2009 | 11:30 PM
  #56
ls1projectirocz's Avatar
Car: 03 Cobra
Engine: 4.6 DOHC
Axle/Gears: 4:10
Car is sick man....what do you have done to the 6.0?? I'm probally going to go lsx block if my funds allow.
Old Jan 4, 2009 | 07:55 AM
  #57
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
preciate that.
ive ripped it out. LOL. sold it to a buddy of mine. building a 408 as we speak.
6.0 is stock shortblock, milled ls6 heads(stock valve) electric water pump, long tubes, pulley, and a futral cam. bout it. it ran exceptionally well for the small camshaft. it was just a good combo. i hope my 408 repeats it with better results. the cam was only 235/237 599/602
Old Jan 4, 2009 | 02:10 PM
  #58
white91formula's Avatar
Car: 91 formula
Transmission: t5
Originally Posted by stage20
preciate that.
anymore pics of the door panels ?
Old Jan 4, 2009 | 02:57 PM
  #59
The_Wraith's Avatar
Car: 1984 Trans Am 15th anniversary
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
the 3rd gen door is too wide at the top causing the panel to bow. the only thing cut off are the tabs that stuck up for the 3rd gen trim.
I see what you mean. Let us know how the door frame holds up long term if all is good I maybe consider trimming mine a little more. The main thing im worried about is making the door frame weak. I am happy with my finish but it does seem to put stress on the top of the 4thgen panel as you said , with the thirdgen door being too wide.
Old Jan 4, 2009 | 04:09 PM
  #60
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
only others i have. hope that helps.
Attached Thumbnails started on 4th gen door panels...mmmmm-dscn1940.jpg   started on 4th gen door panels...mmmmm-dscn1941.jpg
Old Jan 4, 2009 | 06:28 PM
  #61
The_Wraith's Avatar
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
Have you done anything with the front top of the door panel yet? The area that needs to be cut up top.
Old Jan 4, 2009 | 09:42 PM
  #62
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
i dont have any of that area, but i will get a couple.
if you werent a 3rd gen guy that knows its been cut, its invisible.
i took minimal amounts off of the panel. literally putting it on and off 20-30 times to get the cut right.
i kept shaving off a 1/16 at a time until the door would shut, and i stopped.
when you look down where its shaved off, all you see is the rubber weatherstrip around the door.
Old Jan 5, 2009 | 07:22 AM
  #63
ssean92's Avatar
Car: sold
ok come up here and do mine....Looks great
Old May 10, 2009 | 01:51 AM
  #64
Slouch's Avatar
here ya go.
Thanks allot jerk, my a$$ will be sore for a month from the brick I just ****...
Old May 10, 2009 | 10:20 AM
  #65
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
im going to guess thats a compliment. i didnt see a smiley.
Frozer!!!
Jan 19, 2024 04:55 PM
Casey Meyers
Mar 2, 2016 10:46 AM
BlackTopKing
Aug 19, 2015 12:13 PM
AkDrifted
Aug 17, 2015 07:45 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
