1988 Trans Am GTA Digi Dash
Old Sep 13, 2008 | 09:04 AM
LagunaSeca's Avatar
I got a 88 trans am GTA with the digital dash, and I need some help. The dumbass system check is annoying the crap outta me. I replaced the two front fog lights, but the damn thing beeps about every 2 secs and it says R Foglamp, then L Fog and it wont shut the **** up! My other quetsion is about the odometer screen. The back light on the screen does not work anymore, so do I have to get a new screen? or is it just a bulb? thanks
Old Sep 13, 2008 | 09:41 AM
72vega's Avatar
Car: 2008 Silverado, 73 LeMans, 1987 GTA
Engine: 4.8, 350 Pontiac, 350 LT1
Transmission: 4L65E, TH350, T56
Axle/Gears: 3.42, 2.73, 3.42
Re: 1988 Trans Am GTA Digi Dash
f lamp is for front lamps meaning headlights. look at the bulbs and make sure they not mismatched. mine were. i bought 2 new sylvania tru view lamps and it cured the problem. it could also be corrosion on the headlight connectors. as for the odom the bumb can be replaced. its a small halgen bulb that costs 10 bucks. i tried to get away with a 194 but its not bright enuf. so i bought the 10 dollar halogen bulb and its fine.
Old Sep 13, 2008 | 09:59 AM
LagunaSeca's Avatar
Thanks you very much. I was going to get some sylvania silver stars anyway. The two front head lights are mismatched. One is stock and one is not. And you can get the bulb for the screen at auto zone right?
Old Sep 13, 2008 | 01:45 PM
72vega's Avatar
i believe so. i got mine at oreillys and they have the same stuff. pull it out just to make sure what it is tho since its so expensive.
Old Sep 20, 2008 | 05:47 PM
theimpaler68's Avatar
Car: 86 T/A & 88 GTA
Engine: 305 LB9 TPI & 350 LO5 TPI
Transmission: Jasper 4L60 x2
Axle/Gears: 2.77/posi LSD & 2.73/posi LSD
r lamp is the tail lights. even if they work fine one bulb half shorting can cause a problem too.
The_Phoenix
Feb 4, 2016 07:10 AM
stalkier
Aug 13, 2015 12:59 PM
gta power
Aug 13, 2015 06:15 AM
blacksunshine'91
Interior Parts Wanted
Aug 10, 2015 12:04 AM
stalkier
Aug 7, 2015 04:49 AM
