Help with High Beam Switch
Old Oct 13, 2008 | 04:40 PM
87TTops's Avatar
Car: 1987 IROC-Z
Engine: LB9
Axle/Gears: BW 2.77
I was replacing the wiper/turn signal switch and when I removed the smallest plastic part of the trim on the steering column, the part that the tilt lever goes through, I apparently disassembled the linkage between the high beam rod (that goes down to the switch itself) and the turn signal switch. A plastic piece fell out that apparently transfers the motion from the switch to the rod, but I can't figure out how to put it back together. If someone could describe how it's supposed to go together, that'd be great. I can try to post pics of what I'm talking about if needed.
Old Oct 20, 2008 | 11:08 AM
SpeedJunkie's Avatar
Car: 88 IROC
Re: Help with High Beam Switch
No lie, I did the same thing about 5 years ago.....
I now reach down and push the white box manually haha
Old Oct 20, 2008 | 11:58 AM
89RESTO's Avatar
2011 Norwood Gathering
ThirdGen Camaro Rep
Car: 1989 IROC
Engine: 5.7
Axle/Gears: 9 bolt 2:77
It's been a long time since i had mine apart and it's not an easy thing to explain without visual aids but i will tell you what i recall. the small plastic piece that actuates your hi beam rod slips into the small housing of the steering column,the round end with the groove fits against the actuating rod and the other end should have a tab that the blinker arm actuates.
hope this helps, good luck.
GTAman
Mar 15, 2019 11:40 AM
Slush92RS
Sep 2, 2015 08:56 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
Fronzizzle
Aug 19, 2015 01:36 PM
Fronzizzle
Aug 17, 2015 02:52 PM
