Power hatch release
Old Oct 14, 2008 | 11:40 PM
fadedirocz28's Avatar
Car: 1985 Camaro Iroc-Z
Engine: LB9
Power hatch release
What would cause the release to pop it and work 80% of the time, but the other 20%, you hit the switch and nothing at all happens?
(Have to open it with key when it doesnt work)
Is this a common problem?
Old Oct 15, 2008 | 07:47 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Power hatch release
It could be a bad ground at the body ( unbolt the solenoid from the bracket and re-install ) or it could be a bad connection at the button - or a bad button ( Simply replace it. )
My Guess is that the button is probably just wearing out.
Old Oct 15, 2008 | 10:01 AM
WSX123's Avatar
Car: 1988 Trans Am GTA
sounds right thats what i would try too.
Old Oct 15, 2008 | 12:52 PM
Engine: LB9
When it doesn't work, i can pop it open with key and close it, then go hit the button and it pops perfect though?
Old Oct 15, 2008 | 01:04 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
mine does the same thing, i just replaced my pull down motor and it does this, plus after i start the car i have to pop the latch let the pull down come up then close it again or it sounds like my lid didn't close, i have a spare wire on this new unit that my other didn't have, think that could be my problem.
But it is very annoying having my hatch release only work 80% of the time.
Old Oct 16, 2008 | 12:47 PM
John in RI's Avatar
It could very well be that way because there is a poor ground at the body. The soleniod gets grounded to the body once it's bolted down. If you slam the hatch - it's possible that it moves the soleniod a little causeing a "good" ground again. Hit a few bumps and you might loose the ground. Try unbolting it and then re-installing to see if that helps !
Old Oct 17, 2008 | 05:41 PM
Fords88Bird's Avatar
Car: '88 Firebird Z20
Engine: 305 TBI w/TBI mods
Axle/Gears: Stock
Faded ur lucky mine doesn't work 100% of the time, I got to trace connections to fix it. Later.
Old Oct 22, 2008 | 10:41 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Everone does have the ground wire installed that goes from the 10mm screw attaching the solenoid to the hatch pull-down unit to the ground location on the body? That wire must be there because the solenoid is electrically isolated from ground by the guides in the track.
Lon
Vintageracer
Jan 10, 2020 05:33 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
sailtexas186548
Aug 24, 2015 10:11 PM
neekolzun
Aug 24, 2015 04:59 PM
stalkier
Aug 13, 2015 12:59 PM
