Problem Ignition Cylinder/Loose Tooth Steering Column
Old Oct 24, 2008 | 12:31 AM
VEGASIROC's Avatar
Transmission: Manual
In regards to the Loose Tooth Steering Column:
I have a 1990 IROC with airbag. I just started putting everything back together after tightening the 4 buried bolts. I'm at the point where I have the ignition cylinder re-installed. I assume there is only one way the cylinder slides in and mates with the inner column piece. The key turns and all the connected moving internal parts seem to be working properly. The problem is when I turn the key there is no "spring back type return" nor does the car have any power (no buzzer,does not start,as if battery was dead). The headlights work as well as the horn. I just wanted to check it before everything else was re-installed. Is this normal or do I have a problem? Do I have to finish putting everything back together first for it to work?
Any suggestions would be appreciated.
Dan
Jorlain
Aug 24, 2022 05:11 PM
Out-Cast
Mar 22, 2019 09:39 PM
Out-Cast
Aug 23, 2015 06:33 AM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Bull86
Aug 10, 2015 05:43 PM
