Tooth Off Ignition Cyclinder
Transmission: Manual
Hello,
I'm still battling putting back together my steering column after tightening up those 4 loose bolts. I have the ignition cylinder reinstalled but when I turn the key there is no "spring back" action or power to start the car. The headlights and horn work. I have been told by a fellow member I may be a Tooth Off on the Ignition Cylinder. Does anyone know how to check and fix this problem? Also, I assume the cylinder can only slide back in the column one way? Please help, I need to get my car running again.
RedLeader289
May 28, 2019 01:47 PM
Gunner242
Dec 25, 2015 04:49 PM
1Aauto
Sponsored Vendors
Sep 23, 2015 12:56 PM
