1982 TA Seatbelts needed please.
Old Oct 30, 2008 | 05:09 PM
bigmacnz's Avatar
We are rebuilding a 1982 TA.I need a set of tan seat belts that suit the ttop model.The set i have is the old manual type but would like the auto retract version for the front and back.
Old Nov 1, 2008 | 10:38 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Re: 1982 TA Seatbelts needed please.
They should already be the retracting type, if they are original.
The front belts just had the roof-mounted retractor in 82; 83-92 had a second retractor mounted down by the doorsill and require a different plastic sill plate to accommodate this.
The rears from 82-88 have a retractor on the outer mount; in 89 they switched to the over-the-shoulder rear belt which had it's retractor mounted in the rear cargo area.
I *think* 4thgen front belts are a direct swap into the 82.
Old Nov 10, 2008 | 09:48 PM
gtopercy's Avatar
I have just taken a set of tan seat belts from a 82 TA
let me know if you still need them and I will check to make sure they are all here.
Old Nov 10, 2008 | 11:17 PM
bigmacnz's Avatar
Yes i do thanks.
If you have any pics pls send to bigmac@paradise.net.nz
IROCZ1989
Jan 24, 2016 03:55 PM
dutch930
Sep 11, 2015 06:58 AM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
