what is the right price for carpet installed?
Old Nov 8, 2008 | 05:17 PM
rlapenna's Avatar
Car: 1988 Iroc Z Convertible
Engine: 5.0 TPI LB9
Transmission: 5 Speed
Axle/Gears: 3.08
its an 88 iroc convertible. not sure if i want to do the trunk or not. feedbsck appreciated. consodering doing it myself but not sure if i want the hasssle and i cant find medium beechwood.
Old Nov 9, 2008 | 11:42 AM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
Re: what is the right price for carpet installed?
I believe, www.yearone.com has medium beechwood. Def. do it yourself. I have seen a lot of botched carpet jobs done by "Professional" shops. If you buy molded carpet from year one or some other place, installing it is easy. No one will care for your car like you do!
You can also check:
www.classicindustries.com
Good luck!
Old Nov 10, 2008 | 07:20 PM
Fords88Bird's Avatar
Car: '88 Firebird Z20
Engine: 305 TBI w/TBI mods
Axle/Gears: Stock
. Do it yourself, it'll take a couple hrs. but you'll save some $$. Later.
Old Nov 10, 2008 | 09:19 PM
dust3r's Avatar
Car: 1986 z28 & 1992 z28
Transmission: 700-R4
I installed new carpet back in august, it isn't difficult at all if you take your time making the cuts in the correct places. The first cut is always the most difficult. After you make the first cut (I chose to cut out the holes for the center console first), try to look through the hole to figure out where to make the next cut. All I needed to cut for the installation was a hole for the rear of the center console (This hole is for the screw that holds the console to the floor), a hole for the shifter and e-brake, and I needed to trim the carpet along the sides (under the door sills). Other than that, all that is needed is to make slits for the seat bolts to stick up through and holes for the seatbelt bolts to go through. I used an ice pick to located the seat belt bolt holes and the seat bolts are easy to locate through the carpet. No modifications were made to the rear piece of carpet.
Also, I purchased my carpet on ebay. I found the best price for premium acc carpet with mass backing to be on ebay for $400 shipped to my door. For the regular carpet without mass backing, they charge $255 shipped. I bought my carpet from autocarpetoriginals1.
Old Nov 11, 2008 | 08:13 AM
rlapenna's Avatar
Engine: 5.0 TPI LB9
Axle/Gears: 3.08
You can also check:
Good luck!
I've looked on a bunch of sites and I do not see the "Medium Beechwood" I have seen Cognac, Medium Beige, Doeskin, etc. Does anyone know the closest match. it is difficult to tell by the small pics. I suppose I should ask for some samples.
Old Nov 11, 2008 | 08:19 AM
rlapenna's Avatar
Engine: 5.0 TPI LB9
Axle/Gears: 3.08
I didnt realize there were that many holes to cut. was it a molded carpet? I thought the console comes cut out already?
Old Nov 11, 2008 | 03:00 PM
dust3r's Avatar
I believe you can get the carpet with the console cut out, but I wanted to cut it out myself. Yes, it was the molded carpet...its the same carpet that you would get from classic industries, www.stockinteriors.com, etc.
Vintageracer
Jan 10, 2020 05:33 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
lee01
Apr 9, 2016 01:56 PM
Reddeath210
Oct 6, 2015 08:20 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
