turning back the odometer...
Old Nov 23, 2008 | 03:15 PM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
for a while I've had suspicions that my odometer is turning backwards when I'm in reverse. Today I tested it and drove about 2/10ths of a mile in reverse, and it does turn backwards. Has anyone else noticed this? do all of our thirdgens do this?
Old Nov 23, 2008 | 03:24 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: turning back the odometer...
that because its a 82-90 camaro, and it has a speedo cable, so i can see that happening, birds after 85 have electric speedos and camaro over 90 have them as well. I dont think the electric one sping backwards.
Not planning to put the car on jack stands to try to remove mileage are you ....
Old Nov 23, 2008 | 03:26 PM
klause83z28's Avatar
Car: 83 z28
Engine: boat anchor 305 (ex CFI)
Axle/Gears: 3.23 10 bolt
Mine doesn't. I don't know about anybody else's though.
Old Nov 23, 2008 | 03:30 PM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
You bet I am! Just need to drive it in reverse for 70,000 miles, and I'll have a 10k camaro!
...Just something I noticed that I thought was interesting. You'd think GM would have incorporated something into the odometer to prevent this.
It would be a lot quicker to put it in OD and make the odometer roll over again!
Old Nov 23, 2008 | 03:34 PM
Kevin84Z28's Avatar
Car: 1984 Camaro Z28
Engine: L69 305 H.O.
No, thats not normal operation. They should never be able to go in reverse. Usually you can tell if there has been tampering by simply looking at the numbers. 99% of the time when there has been tampering you'll notice that the last number in the row, either to the right or left never lines up with the rest. It'll be close but never dead on.
Old Nov 23, 2008 | 03:39 PM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
when I got my camaro the odometer was at 74,000. I dont think that someone would mess with it and set it to 74,000. Maybe it happened long ago...
Old Nov 23, 2008 | 03:41 PM
Stephen's Avatar
Car: 87 GTA
My 87 GTA doesn't roll its #s backwards...I was doing some work & didn't wanna drive around the block every 10 minutes, so I put it on jackstands.
Old Nov 23, 2008 | 03:45 PM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
assuming this is correct, it wouldn't in an '87 GTA
apo_bailon15
Mar 28, 2016 05:20 AM
tnrednneck
Aug 13, 2015 08:57 AM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
Tony Ferrarri
Aug 11, 2015 07:59 PM
