Dash swap???
Old Dec 6, 2008 | 03:08 PM
myroc86's Avatar
Car: 86 Camaro
Engine: 350 LT1
Dash swap???
I have a digital dash from a 86 Camaro with the 2.8FI that im in the middle of selling to a guy with a 86 Camaro 305 convertible basically what im asking is has anyone done a swap from mech/analog to the digital? If you have was there alot of electrical work that you had to do other than swapping the pcm or was it just pretty much straight up? Hes really interested in it and i just want to get it out of my garage. All help is apriciated. thanks
-Mike
Old Dec 7, 2008 | 10:01 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Dash swap???
Ya'.... I've made the swap more than once. No - It's not an easy swap. The wiring is pretty compatable between the 2 cars as they are both 86's & should have each used a separate wiring harnesses; 1 for the Motor and 1 for the ECM ( unlike later cars that use a single harness for everything. )
The problem with this swap is that all the other parts of the interior are also needed. The Whole interior Heater box and Wiring system must be changed if you want heat,..... the correct Seering Column should be used, the "normal" Camaro center console doesn't line up to a berlinetta dash, and so on. As far as wiring, beside changing the entire Heater/AC harness, The wiper wiring at C100 will have to be re-pinned or the wiring will need to be spliced. The more parts you have from the donor car - the better the chances of making this swap a success !
Do a search and you will find more detailed posts on this topic !
Jorlain
Aug 24, 2022 05:11 PM
The_Phoenix
Feb 4, 2016 07:10 AM
Pilotrick50
Sep 2, 2015 12:48 PM
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
Vintageracer
Aug 11, 2015 08:13 PM
