removing choke light & buzzer
Old Dec 13, 2008 | 06:58 PM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
how do i disable the buzzer for the choke light? where is it located? Also, does the horn button just pop off with a screwdriver? If not, how does it come off?
Old Dec 13, 2008 | 07:25 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: removing choke light & buzzer
There isn't a buzzer for the choke. Any noise is coming from the choke relay, and is a sign that there's something wrong with your choke circuit.
Old Dec 13, 2008 | 07:35 PM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
oh... so where is the choke relay, and how do i identify it? It sounds like the noise is coming from near the choke light, or from inside the dash, and it starts when the choke light comes on.
Old Dec 13, 2008 | 08:15 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Check the choke heater fuse.
Old Dec 13, 2008 | 08:28 PM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
i don't have a choke on my car, so even if this is only because a fuse is blown, I would still like to know how remove the relay.
Vintageracer
Jan 10, 2020 05:33 PM
stalkier
Aug 21, 2015 01:54 AM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
3rdgenparts
Aug 8, 2015 07:09 PM
