swap solid rear seat to split rear seat
Old Dec 28, 2008 | 11:47 PM
1982TA's Avatar
Car: 1982 Trans Am
Engine: SBC 400
Transmission: 700-R4
Axle/Gears: 9 Bolt 2.77
I'm just wondering if anyone has swapped out the solid rear seat back to the 2 piece split seat back. I know there is a bracket in the middle of the split seats that hold them in place. I took some apart a while back, but I'm just now thinking of converting my rear seats to split. I cannot remember how the bracket is secured. Is it welded, bolted?? I know I will also need to have the latch striker for the drivers side also. If there is a lot needed to do this, I may just pass...I just wanted to know what is involved and if there is a lot of work involved.
Old Dec 29, 2008 | 01:16 AM
Stephen's Avatar
Car: 87 GTA
Re: swap solid rear seat to split rear seat
Spot welded.....I wonder just how hard t would be to line one up, that you cut out of a junkyard car? I supposed if you took PLENTY of measurements from reference points, before cutting it off, you could line it up in the correct spot on your car.
I almost wouldn't be surprised to find out ALL the cars had the brackets, regardless of split or sold seats, to make assembly ru than much quickly & smoothly.
Old Dec 29, 2008 | 04:37 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
The cars with the solid backseat won't have the bracket. It is spotwelded to the car, but you could probably break the spotwelds with a hammer and chisel from a junkyard car. Or, bring a cordless drill, and drill them out.
Old Dec 29, 2008 | 07:00 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Sure. Check the following how-to:
https://www.thirdgen.org/splitseat
JamesC
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
