Running a wire from trans to inside car
Old Jan 2, 2009 | 11:10 AM
Revdoc's Avatar
Car: 89 GTA
Axle/Gears: 3.27:1 9 bolt
Getting ready to finish wiring up my trans temp gauge and wondered if there was an easy way to route the sensor wire from inside the car to the transmission. A hole in the floor would be easiest, hopefully one already exists with a grommet. I know I can run it out the firewall and down along the floorboards but I'm hoping there's an easier way. Is there a hole under the center console where the shifter cables go? Car is an 89 GTA 700R4.
Old Jan 2, 2009 | 01:28 PM
The_Wraith's Avatar
Car: 1984 Trans Am 15th anniversary
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
Re: Running a wire from trans to inside car
Take your console out and you will see the shifter cable openings just drill a hole there and put a rubber grommet in that would be easiest.
Old Jan 2, 2009 | 02:34 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
yeah, there is already a large hole that the shifter cable runs through with an attached grommet. you could probably squeeze it in between the cable and its existing grommet.
1992 Trans Am
May 10, 2023 07:19 PM
midge54
Dec 27, 2019 04:14 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Exxon Limited
Aug 9, 2015 08:13 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
