Changing to a rear hatch pulldown in 1982 TA
Old Jan 7, 2009 | 06:18 AM
bigmacnz's Avatar
I have the pulldown unit,bracket and rear panel from a 88 GTA that i would like to put on my 82 TA
Before i start the work does anyone know if i will have problems with the rear cargo door closing or anything else?
Old Jan 11, 2009 | 12:15 PM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
Re: Changing to a rear hatch pulldown in 1982 TA
Honestly save yourself the headache and keep the manual rear hatch. The pull down motors are fragile and i have to be around my car at all times. I had a roommate one time that went to slam my hatch and i had to run and shout at him to stop. I grabbed it just in time. If you slam them with the pull down motor its only a matter of time before they break. They were the worst feature of these cars in my opinion and are useless. I mean...whats the point?
Old Jan 11, 2009 | 08:17 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
The bracket for the latch is different, and spot welded to the car. It can be swapped, just drill out the spotwelds, then weld the new bracket to your car. I agree that the pulldown motor is pretty useless though, just one more thing to break. The power release is handy though, and you can add power release without swapping the brackets.
Vintageracer
Jan 10, 2020 05:33 PM
madsv1000
Aug 20, 2015 06:45 AM
stalkier
Aug 13, 2015 12:59 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
z28addict8490
Aug 7, 2015 08:48 PM
