92 gauge cluster removal
Old Jan 19, 2009 | 11:34 PM
92rscamaro_305's Avatar
ok i have a 92 camaro rs and the lights in the gauge cluster r burnt out and i cant seem to figure out how to get the cluster out to replace them so i was wondering if someone can give me a step by step on how to do this. also i was need to know how many bulbs r in the cluster and i was wondering if in the gear indicator there should be any lights cause i think they to may be burnt out
Old Jan 20, 2009 | 05:57 AM
IROCZ28KevinZ's Avatar
Car: 1991 Z28 convertible
Transmission: TH-700R4
Axle/Gears: 3.73 posi 4th gen 10-bolt
Re: 92 gauge cluster removal
you'll need to drop the driver's side underdash panel, it's held on with a couple torx screws IIRC. Then you can acess the screws holding the cluster trim on, you'll need to remove those. Also, once that underdash panel is off, reach up behind the headlight switch, there is a little button you push and the **** will come off. After all the screws are off the tri,. pull it off, it's held on the rest of the way by clips. Remove the 4 screws holding the gauge cluster and out it should come.
You may have to lower the steering column a wee to get it out, there are two 13MM (IIRC) bolts that hold it up, you can see them after you remove that underdash panel.
Old Jan 20, 2009 | 12:34 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
There are 4 bulbs in the gauge cluster to illuminate the gauges, and 1 bulb for the gear indicator.
This info is already on this board, you just need to try a search
Frozer!!!
Jan 19, 2024 04:55 PM
Jeremys87
Jul 14, 2022 09:08 PM
fonzie85
Aug 13, 2015 11:50 AM
ChevyZ71
Aug 13, 2015 07:30 AM
