2000 firebird interior into 3rd gen
Old Jan 28, 2009 | 09:11 PM
z28fever's Avatar
i have looked at what the 4th gen camaro dash swap but i have come across a set dash/console/doors off of a 2000 firebird.... are they the same fitment as a 4th gen into a 3rd gen? what are the differences? etc just sprawling for info
Old Jan 28, 2009 | 09:35 PM
z28fever's Avatar
Re: 2000 firebird interior into 3rd gen
did some more digging, they look about the same but as far as the gauge cluster, im assuming that that wont work out to well, and would have to be replaced with a 98ish camaro cluster from a v-8.... im not looking for a how to, but before i spend $250 on everything i wanna make sure i can make it work
any help would be great!
Old Jan 29, 2009 | 09:31 AM
z28fever's Avatar
no opinion? nobody done it?
Old Jan 29, 2009 | 09:49 AM
DJ Delsym's Avatar
Car: 86 Iroc
Engine: Soon to be LS 6.0
Transmission: Soon to be mn12
Axle/Gears: Strange 9in 4.10
Anything can be done, it is just harder for some. I have not done any fourthgen swaps but I do know that the door panels require modification for use and the intrument panel could be an issue because it's looking for a signal from the ECM. I would look around a bit more across the internet, good luck with your swap. Don't forget pictures if you go through with it.
Old Jan 31, 2009 | 10:20 AM
The_Wraith's Avatar
Car: 1984 Trans Am 15th anniversary
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
There will be no ECM issues with a pre 97 cluster. The topic has been beaten to death around here do a search.
Old Jan 31, 2009 | 07:48 PM
z28fever's Avatar
I have done as much research as i can just about do on this site, and yes i know this has been beaten like a bad child on this site, but that is specifically for the camaro dash..
i am fully aware that camaro and firebird parts for the greater amount are completely interchangeable, but as with any project... i want to see if anyone knows about specific details etc
if it was a camaro dash, i wouldnt have to ask, but since its a firebird one, i want to make sure before i spend money on something that isnt/is going to work.
thank you for the info on the pre 97 cluster, as i was reading through threads, it appeared that a 98 cluster was the best suitable choice
Old Feb 1, 2009 | 10:45 AM
The_Wraith's Avatar
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
The dash from both camaros's and birds bolt up the same and wire up pretty much identical too. Essentially they are the same dash frame with different face. 98+ cluster is not the suitable choice unless you have an engine swap. The 98 and up cluster requires mods to get everything working. For instance you can take out the fuel gauge and put in a older one to get that part working. But still why bother when you can get a older cluster?
Old Feb 1, 2009 | 02:42 PM
z28fever's Avatar
well my fuel gauge doesnt work anyways, but that's for a different thread
thanks a bunch for the info
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
IMissMy86TA
Aug 31, 2015 08:40 PM
E Rod
Aug 28, 2015 05:17 AM
reiderz iroc
Aug 13, 2015 04:57 PM
