anyone make there own door panels? aluminum?
Old Feb 2, 2009 | 03:18 AM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
87 formula 350. one door panel was messed up due to a missing window when i bought the car. just got sum universal aluminum door panels that i have to trim to fit. but i also want to mount a 6.5" speaker in the door. if u made aluminum panels for either firebird/camaro post them and give me sum ideas.
Old Feb 2, 2009 | 05:50 PM
Mathius's Avatar
Re: anyone make there own door panels? aluminum?
Can't remember where I saw it, but there was a race car that was finished off with aluminum panels and they stamped flames into each and every panel. Came out real nice. I know one of those Monster Garage books detailed a simple way to get that effect... I think it was "how to fabricate damn near anything".
You basically use a torch and some 1/4" or some type of thick metal to burn out your flame pattern so that you have a set of flames, plus the cutout that the flames came out of. You clean up the edges, throw your aluminum panel in between them and press them. You might be able to do it with wood or something and a hammer. You'd have to experiment.
In the book they used 1/4" and then ran it over with a bus to press it.
Mathius
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
