Why does my car have a mechanical speedo?
Old Feb 4, 2009 | 07:44 AM
87v6Bird's Avatar
Car: 87 Firebird, 89 Trans Am
Engine: 406, LB9
Transmission: T56, 700R4
Axle/Gears: 3.23 Torsen, 2.73 Posi
For months I had been planning my gauge swap in my Firebird. I had read all the articles and knew that my car had an electronic speedometer. After finally getting a new set of gauges I began to do the swap. There was one problem though my car has a mechanical speedometer!
Why does my car have a mechanical speedometer? It's an 87 so it should be electronic. Also I know nothing about the car has ever been changed because the previous owners were family.
The pics are of the speedometer cable. I know it's hard to tell.
Attached Thumbnails Why does my car have a mechanical speedo?-img_0607.jpg   Why does my car have a mechanical speedo?-img_0609.jpg
Old Feb 4, 2009 | 08:02 AM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Re: Why does my car have a mechanical speedo?
It could be because your a base model v6, or possibly an early 87 and they were getting rid of parts. I'm not sure of this because i've read the same things that you probably have about the switch to digital earlier in the firebirds than in camaro's and in the junk yard i've notices that it's hit or miss. To be honest i haven't even checked my guages in my '88, but i think that it's digital...i hope...
Old Feb 25, 2009 | 07:38 PM
1986Firebird350's Avatar
Car: 1986 Firebird
Engine: 350 SB Chevy
Transmission: TH350
I have an 86 firebird and I have the mechanical speedo. It was originally the V6, but it had the engine swap done. Depending on what kind of gauges you bought, you're going to need an electrical pulse sender for them to work at all. Just referring to the one from autometer, it screws right into the tailshaft of your tranny where the mechanical cable is situated right now. After it's screwed in, you need to have it wired with a switched 12V source and wire the sender wire up into your gauge cluster which goes to one of the terminals on the speedo. After this, you're going to have to program it with the instructions that came with the speedo. Hope this helps!
Old Feb 25, 2009 | 07:56 PM
87v6Bird's Avatar
Engine: 406, LB9
After much searching, I have since discovered that apparently base Firebirds kept the mechanical speedos after the 1986 switch to electric that you see most people refer to. I guess I should have done a more thorough search. Since I don't really feel like wiring in a VSS I guess I'll be living with what I have. Thanks though.
Old Feb 25, 2009 | 08:28 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
I thought the vss started in 88?
My 87 Camaro had a speedo cable and it was all original.
My 88 firebird(long gone) had a vss.
Old Feb 25, 2009 | 08:40 PM
87v6Bird's Avatar
Engine: 406, LB9
Firebirds switched before Camaros. I believe Camaros switched in 1990 but I may be mistaken. Why GM did that is beyond me.
Old Feb 25, 2009 | 10:50 PM
Car: 1986 Firebird
Transmission: TH350
Well, if you wanted a diff speedo than stock, i would definetly put the effort in to wire it up and get a more attractive and accurate gauge. Can't call yourself a hot rodder if you don't put the effort!
Old Feb 26, 2009 | 12:29 AM
87v6Bird's Avatar
Engine: 406, LB9
I'm not attempting any kind of hot rod. I just wanted oil, water, tach, and voltage. And I wanted everything to still look stock. Hence me trying to find a stock cluster with instruments.
Jorlain
Aug 24, 2022 05:11 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
gwade12
Aug 8, 2015 08:17 AM
beachrodder
Aug 7, 2015 04:27 PM
