How can I adjust my seat (when sitting, leans to the left)?
Old Mar 6, 2009 | 10:42 AM
majobis's Avatar
Car: 1987 IROC Z w/T-Tops
Transmission: Automatic
Axle/Gears: G92
Hi All,
I recently purchased an 87 Iroc with the six-way power seat. It does have some miles on it, so I didn't expect these flimsy seats to be perfect. However, it is quite uncomfortable, especially since when I am sitting in the drivers seat, I feel that my body is leaning toward the door, instead of being centered.
This is felt more on the bottom cushion. The top cushion, other than being too far tilted back, is centered.
Any way to adjust the bottom cushion on a power seat frame?
Thanks in advance!
Old Mar 6, 2009 | 10:47 AM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
Re: How can I adjust my seat (when sitting, leans to the left)?
if it's the seat bottom more than the back, is the foam worn more on that side? there really isn't an adjustment for it. Either the seat frame is tweaked or the foam wore excessively and unevenly. Seat swaps are very easy though, only 4 bolts and 1 wiring harness connection for the power seat track.
Old Mar 6, 2009 | 11:55 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The problem may have more to do with the power seat track than with the cushion. Try raising the seat all the way up (you may find that the low side will keep going until it matches the high side).
JamesC
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
db057
Sep 4, 2015 07:57 AM
bdads
Aug 24, 2015 06:01 PM
