4th gen carpet
Old Mar 9, 2009 | 10:37 PM
87iroczeh's Avatar
Car: 1987 Iroc Z
Engine: 5.7 L TPI
Transmission: TH700-r4
4th gen carpet
Will 4th gen carpet fit in a 3rd gen?
Old Mar 9, 2009 | 10:43 PM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
Re: 4th gen carpet
no
Old Mar 10, 2009 | 09:11 AM
Dogfrost9's Avatar
Car: 1984 Camaro
Transmission: 350 Turbo
Re: 4th gen carpet
Iv heard that you cannot directly swap them, but if you trim the carpet in some places you can get it to work fine. You would have to ask someone that has already done this to know where exactally to cut. If you get some 4th gen carpet cheap enough you could try to figure that out yourself. up to you.
Old Mar 10, 2009 | 10:26 AM
mmm88TA's Avatar
Engine: 5.0 TPI
Transmission: TH700R4
Axle/Gears: 3.43 posi
Re: 4th gen carpet
I have one layed in my car now i'm not trimming it until I dye my plastic and reinstall them but so far the only spots that were different were the passenger seat area and the front seat belt mounting locations. the 4th gen carpet is also longer and reaches into the hatch area whereas the 3rd gen one stops at the rear seats. I haven't put the seats in yet but the holes for the seat mounts seem to line up ok. hope that helps. BTW the carpet is from a 93 Camaro and I put it in my 88 Trans Am
Old Mar 10, 2009 | 10:33 AM
shaolink9's Avatar
Car: 1986 z28 <sold>
Engine: iron head 383
Transmission: th350
Axle/Gears: 4th gen 3.23 posi
Re: 4th gen carpet
mine fit and i didnt trim it...the part u need to trim the seats pretty much cover. also make sure u get the carpet for the trunk.
Old Mar 10, 2009 | 10:39 AM
mmm88TA's Avatar
Engine: 5.0 TPI
Re: 4th gen carpet
You were able to get the trunk piece to fit? I have it but didn't put it in yet didn't look like it'd even be close to fitting. any pictures?
Old Jul 7, 2009 | 09:41 AM
88FormulaKiller's Avatar
Car: 1967 Firebird P.T.
Engine: LS3 4" Strkr 422ci
Transmission: MN12 6 speed
Axle/Gears: 3.73 8.5" 10 Bolt Eaton
Re: 4th gen carpet
old post but i thought this would be useful, i just swapped a 4th gen carpet into my 88 formula and the only issues were the front seat belt area needed to be notched on the outside under sill plates, the passenger side kick panel needs a little trimmed off side to fit under sill plate and kick panel where they slide together, obviously the rear of the carpet needs to be cut back in which case i just slipped it under the rear hatch carpet and the holes in the carpet for the front female seat belts on the tunnel need to be cut since they dont line up(which is easy to do since the 4th gen holes are there as a guide and can be covered up with floor mats). other than these minor details its a direct swap. looks great too, especially if you have all black interior with a gray carpet and black floor mats, has a nice contrast.
Reddeath210
Oct 6, 2015 08:20 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
cam-mike
Aug 24, 2015 07:23 AM
