hole in the floor
Old Mar 25, 2009 | 11:31 AM
ellocojorge's Avatar
Car: 1991 camaro rs
Engine: 305 tbi
Transmission: t5
Axle/Gears: stock
hole in the floor
my car has a factory hole in the passenger side floor. it is cover by a thin piece of metal coverd with thick gummy silicone. it recently started leaking, has anyone had this problem?
Old Mar 25, 2009 | 11:34 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: hole in the floor
leaking? How deep of water are you driving through? I think you'll find it's collecting water from a failing heater core, or your t-tops, if you have them, or something like that.
Old Mar 25, 2009 | 12:02 PM
Slave One's Avatar
Car: 1991 Camaro RS
Engine: 5.0 TBI
Axle/Gears: 3.08
Thats what I was thinking
Old Mar 25, 2009 | 12:35 PM
Car: 1991 camaro rs
Engine: 305 tbi
Transmission: t5
Axle/Gears: stock
sometimes puddles are deep... i remove the carpet, and found there was a square patch of silicone, but some was missing( this was in that relly low area of the passenger floorbord..) so i took out the silicone, and out popped a metal plake..... there was about a 4inch oval hole( its factory made) i checked and there are a total of 4. 1 in the front passenger oone in back... same in the drivers side...... i know it didnt leak trough the window because all of the carpet was dry but that spot.... if u check underneath the car u can see them, there is one right by the cathelitic converter
Old Mar 25, 2009 | 12:40 PM
Chevy8588's Avatar
Car: 1987 Iroc Z28/ 1982 Z28
Engine: 355 TPI IP/ 305 CFI
Transmission: T-56/ 300C
Axle/Gears: 3.42 Open/ 3.73 Posi
lol it converts anyone who touches it into a catholic! (sorry, had to)
Old Mar 25, 2009 | 12:59 PM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
sounds like your heater is leaking. that it where we all get water when they leak, on the passenger side on the floor.
is it clear water or does it look like antifreeze?
did it show up on a day you turned on your heater.
if its the heater its a cheap fix, but it will take forever to do it.
Old Mar 25, 2009 | 02:58 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
I know about the plugs, but for the tire to splash water through the passenger side one, you'd hafta be making a tight turn at a relatively high speed. Even then, it's not like the plug is a scoop. Put your best friend in the passenger seat, then have them check for leaks while you pour water around the window and T-top, if your car has t-tops. If it's not that, it's probably the heater core.
Pac J
May 17, 2020 10:44 AM
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
LC2 TECH
Oct 13, 2015 11:53 PM
drumstixer
Sep 29, 2015 03:02 PM
