HVAC issues
Old Apr 22, 2009 | 02:41 PM
red/white04's Avatar
Car: 88 IROC
Engine: 305TPI
HVAC issues
ok..so i just did an A/C delete on my 88 Roc. when i change the controls from off to on it works just fine...all low-high works on the blower. but it will not change off of defrost(the lever moves just fine) is this vacuum controlled? i know there are two vacuum lines that enter just behind the motor and i know one has to do with the A/C (coolent routing solenoid, did the delete on that) so is it possible that the other line is for changing from vent to heat(feet), face and any combo there....
Old Apr 22, 2009 | 05:45 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Re: HVAC issues
Yes.
Defrost is the default duct setting in the event there is no vacuum. .
Old Apr 22, 2009 | 07:15 PM
Car: 88 IROC
Engine: 305TPI
Re: HVAC issues
thank you that is what i needed to know....
Bubbajones_ya
Jul 6, 2024 08:32 PM
MM2Robinson
Oct 1, 2017 09:16 AM
nova983
European Region
Nov 2, 2015 12:15 PM
TheTraut88
Sep 11, 2015 05:16 AM
Fronzizzle
Sep 8, 2015 12:10 PM
