Is this under column trip panel change possible?
Old May 4, 2009 | 07:04 PM
gcgarner's Avatar
Car: '92 T/A WS6 Vert/1956 Chevy Nomad
Transmission: 700r4 w/ Transgo Kit
Axle/Gears: 3.42 LSD
My car is at the body shop right now, so I can't look to see ...
The plastic trim piece under the steering column in my '88 T/A won't stay up. It's like it doesn't fit right. The previous owner did a security system install, and the panel was pulled for that, but it was not re-installed correctly and there are a bunch of wires crammed in there. There is a plastic tab broken, and it seems like it is pretty much fubar'd IMO.
Anyway, I have the piece off of a '92, but it is totally different. It is metal wrapped in foam padding and vinyl, and I'm pretty sure the bolt holes won't line up, but would this swap be possible? Has anybody done it?
Old May 5, 2009 | 09:51 AM
87_Injected's Avatar
Car: 2010 2LT RS
Re: Is this under column trip panel change possible?
Are you referring to the hush panel? If so then I have one that was sent to me in which was the wrong one for my IROC. I was told it came from a firebird. Let me know. Show me pics of yours and I can tell you if its the same one.
Old May 5, 2009 | 10:33 AM
gcgarner's Avatar
I'll post up a pic when it's back from the body shop. Thanks!
Jorlain
Aug 24, 2022 05:11 PM
Out-Cast
Mar 22, 2019 09:39 PM
Out-Cast
Aug 23, 2015 06:33 AM
Tony Ferrarri
Aug 11, 2015 07:59 PM
